Ethernet Products
5782 Discussions
Can we configure multiple vlan id to a single VF using ip command?
懷曾
Hi everyone,
I wonder that whether I can confiure multiple vlan id to a single VF in Host OS not guest OS using ip command, other command or modify vlan id of VF in PF driver?
For example, for single vlan id is using ip link set eth0 vf 1 vlan 3
But is there a command like ip link set eth0 vf 1 vlan 3,5?
Many thanks.
Hi W180112,
Thank you for posting in Wired Communities. This is not supported since you can only configure one VLAN per VF. Hope this clarifies.
Sharon
Hi W180112,
Sharon
懷曾
Hi Sharon
Thanks for the reply
Hi W180112,
You are welcome. Feel free to contact us if you have other inquiries.
Sharon
