Ethernet Products
5764 Discussions
Disable VMDQ on VMware 8.0U2
ThiasIsso
Hello
We have a problem with ARP pakets on a bridge mode virtual machine they run on an ESXi 8.0U2 host.
The ARP reply where  not send always over the bridge. After research I've found the article from Broadcom.
https://knowledge.broadcom.com/external/article?legacyId=95979
We have non NSX-T but I think it is our problem.
When I tray to disable die VMDQ Loopback then I become  from the ESXi
"It is not possible in this version by the network adapter"
It is an Dell XR4520 node as server. The installed networkcards are "Ethernet Controller E810-C for SFP"
I found the article by Dell knowlage base
https://www.dell.com/support/kbdoc/de-de/000223462/intel-e810-c-adapter-schaltet-vmdq-loopback-via-intnetcli-failed-aus
There is described than Intel know this problem and bring a new driver at Sep 24.
Is a new driver exist?
Where can I download this driver?
Is a beta driver exist, they can I tray in our development system?
Many thans for answer
ThiasIsso
Good morning
It's a long time ago I ask the question.
At the moment wie don't have the problem anymore.
We have change the driver version to Intel icen 1.14.2..
At the time we have check, there where a newer driver available on the Broadcom website.
the newer driver was not compalible whit the Intel net cli tool.
The tool version was 1.13.2.
We use now
- ESXi 8.0U3
- Driver version icen1.14.2
- Net cli version 1.13.2
This combination work  fine
Kind regards
Matthias Witt
IntelSupport
Community Manager
Hi Matthias,
Greetings for the day!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Jerome
IntelSupport
Community Manager
Hi Matthias,
This is to follow up on the issue you reported with us.
Jerome
ThiasIsso
Good morning
We use now
- ESXi 8.0U3
Kind regards
Matthias Witt
Sreelakshmi1
Hi Matthias,
Thank you for sharing the update. We will proceed to close the request.
Please feel free to reach out if you have any other questions or need additional help in the future.
Sreelakshmi
