Ethernet Products
5762 Discussions
Does FM10420 support timestamping of every frame?
vkanc
We are looking at FM10420 controller based NICs. Does this controller support timestamping of only IEEE 1588 frames or every frame? Where can I find a datasheet for this controller?
st4
New Contributor III
Hi vj535in,
Thank you for the post. I am not an expert on this ethernet controller but I found on our ark.intel.com, the specs show the controller support IEEE 1588.
http://ark.intel.com/products/92674/Intel-Ethernet-Multi-host-Controller-FM10420 Intel® Ethernet Multi-host Controller FM10420 Specifications
Hope this helps.
rgds,
wb
vkanc
Hi wb,
Thanks for the response. I found the same specs but we are interested in the detailed datasheet. Fo example, the link below is the datasheet for XL710 controller
http://www.intel.com/content/www/us/en/embedded/products/networking/xl710-10-40-controller-datasheet.html Intel® Ethernet Controller XL710 Datasheet
We need the same info for FM10420.
Vijay
COlar
Hi vj,
Datasheet for FM10420 can be found at http://www.intel.com/content/www/us/en/embedded/products/networking/ethernet-multi-host-controller-fm10000-family-datasheet.html Intel® Ethernet Multi-host Controller FM 10000 Family: Datasheet
A linux version of the fm10k driver can be found on sourceforge at https://sourceforge.net/projects/e1000/files/fm10k%20stable/0.19.3/ Intel Ethernet Drivers and Utilities - Browse /fm10k stable/0.19.3 at SourceForge.net , or 3'd party websites for newer version ( fm10k-0.20.1.tar.gz )
