Ethernet Products
5821 Discussions
E1G44ET2: does this device come with one heat sink or two?
SAatTrio
The pdf shows this device with one heatsink however if you do a Google search this device apparently can also come with 2 heatsinks?
Are these both E1G44ET2 or is one of these being misrepresented?
Achilles_Intel
Hello SAatTrio,
Thank you for the quick update.
We understand your concern about these products. We have discussed this matter with internally and we can confirm that the E1G44ET2 adapter only has one heatsink as you have seen in the document you found.
Kindly let us know if you have further questions or need clarifications. We will reach out after 3 business days should we not receive a response from you.
Thank you and have a nice day.
Achilles M.
Intel Customer Support
Achilles_Intel
Hello SAatTrio,
Please allow us to discuss this matter internally. In the meantime, we hope you don't mind if we ask you the reason for confirming this information?
Let us know if you have further questions or need clarifications. Please allow us some time to check into this matter. We will provide you with an update within 3 business days.
Achilles M.
SAatTrio
Hello Achilles M.
I have a project that requires a few of these EOL products, but the heatsink differences brought up authenticity concerns that need to be satisfied before we can proceed with the project.
Thanks!
Achilles_Intel
Hello SAatTrio,
Achilles M.
SAatTrio
Hello Achilles M.
Thank you for your attention and support with this inquiry! I have no other questions at this time!
Achilles_Intel
Hello SAatTrio,
Since you have no further questions about this matter, this thread will now be closed. Feel free to post a new question in forums if you have questions about your Intel Ethernet products as this thread will no longer be monitored.
Achilles M.
