Ethernet Products
5862 Discussions
E610 SFP+ Support
T555
The E610 mentions SFP+ support in the datasheet, but not the product spec.
Does the E610 (specifically, E610-XAT2) support SFP+? If so, are there any reference designs available?
T555
Going through our support structure, I was able to request access to submit the IPS ticket for this issue (case no. 00955799).
Azhari_Intel
Hi T555,
Greetings to you.
Thank you for posting in Intel Community Forum.
As per product brief, SPF+ modules are not supported on E610-XAT2.
You may refer to the product brief as per link below.
https://www.intel.com/content/www/us/en/content-details/836469/intel-ethernet-controller-e610-xat2-xat-iat2-product-brief.html?wapkw=e610-xat2
Kindly refer on the link provided below for more details as well as reference schematic of E610-XAT2.
https://www.intel.com/content/www/us/en/products/details/ethernet.html
https://www.intel.com/content/www/us/en/content-details/803841/intel-ethernet-controller-e610-xat-xat2-reference-schematic.html?DocID=803841
Azhari_Intel
T555
The product spec does not cover all of the interfaces listed in the datasheet, , particularly, SFP as there is quite a bit of references to SFP in the datasheet as  Table 3-67 - how are these two reconciled?
Simon-Intel
Hi T555,
Thank you for your response. To assist you further, could you please confirm the manufacturer of the board where the Intel® Ethernet Controller E610-XAT2 is embedded? This information will help us provide more accurate support and guidance.
Looking forward to your confirmation.
Simon
T555
I do not have a product with an E610 in it, I'm trying to make one. With the conflicting information, I'm trying to get a better understanding of the capabilities.
Simon-Intel
Hi T555,
Regarding your query, I kindly request you to open an IPS ticket. Please use the link below and select the "Intel Premier Support" option under the "Contact Us" section. Intel Premier Support
If you need further assistance, feel free to reach out.
Simon
T555
Hi Simon,  I've tried creating an IPS ticket - there is no option for E610 support in the product select, which prevents me from creating an IPS ticket.
Simon-Intel
Hi T555,
Could you please confirm which E series network controllers are available for you when creating an IPS case? This information will help ensure that we are aligned with the available options.
Simon
T555
None of "E610," "E810," nor "E830" match to any products in the IPS case creation form.
vish1
Hello T555,
Greetings!!
Could you please let us know which options are currently being displayed? Alternatively, you may create an IPS case using any generic Intel Ethernet product. When doing so, kindly ensure that you mention the actual product and provide a clear description of the issue. Our team will then be able to assist you accordingly.
Vishal Shet P
Azhari_Intel
Hi T555,
Good day to you.
Just wanted to follow up with you, kindly let us know if you have any further concerns.
Azhari_Intel
T555
Poojitha
Hi T555,
Greetings for the day!
Thank you for your confirmation. As you have raised an IPS case for the issue, our dedicated team will assist you further with your query.
Therefore, we will proceed with closing this case.
We appreciate your understanding!
Poojitha N
billylin
Hi T555, were you able to get an answer from IPS? I have the exact question. It's hard to find resources about the controllers and Intel doesn't seem to have updated the datasheet and product brief. They're out of sync like you mentioned half a year ago. Thank you for your time!
T555
It was apparently a mistake in the datasheet to have all that documentation for SFP. I was recommended to pursue the E830 family.
billylin
Ahh, thank you for replying. I was trying to use only 10GE SFP so the 800 series seems to be an overkill for me. Appreciate the help!
