I have an E810-CQDA2 that I'm trying to update the NVM of, but am encountering Update not Available.
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.40.5.5
Copyright(C) 2013 - 2023 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [+.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Connection (17) N/A(N/A) 1A1C 00:000 Not supported
I219-LM
02) Intel(R) Ethernet 100G 2P E810-C N/A(N/A) 1592 00:001 Update not
Adapter available
03) Intel(R) Ethernet Controller (3) N/A(N/A) 15F2 00:005 Update not
I225-LM available
This is a standalone add-in PCIe card, not an integrated controller.
This is inventory output (the card ports are configured as 4x25G at the moment, thus the multiple entries)
[00:001:00:00]: Intel(R) Ethernet 100G 2P E810-C Adapter
Flash inventory started.
Flash inventory finished.
OROM inventory started.
OROM inventory finished.
Netlist inventory started.
Netlist inventory finished.
[00:001:00:01]: Intel(R) Ethernet 100G 2P E810-C Adapter
Device already inventoried.
[00:001:00:02]: Intel(R) Ethernet 100G 2P E810-C Adapter
[00:001:00:03]: Intel(R) Ethernet 100G 2P E810-C Adapter
Vendor : 8086
Device : 1592
Subvendor : 8086
Subdevice : 000B
Revision : 2
LAN MAC : 40A6B795C6A8
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 80008942
SerialNumber : 40A6B7FFFF95C6A8
NVM Version : 3.00(3.00)
PBA : K98023-005
VPD status : Valid
VPD size : 243
NVM update : No config file entry
checksum : N/A
OROM update : No config file entry
CIVD : 20.5.13
PXE : 2.5.0, checksum Valid
EFI : 3.0.11, checksum None
Netlist update : No config file entry
Netlist version : 3.0.24
Customer version : 0
Vendor : 8086
Device : 1592
Subvendor : 8086
Subdevice : 000B
Revision : 2
LAN MAC : 40A6B795C6A9
ETrackId : 80008942
PBA : K98023-005
VPD status : Valid
VPD size : 243
checksum : N/A
CIVD : 20.5.13
Vendor : 8086
Device : 1592
Subvendor : 8086
Subdevice : 000B
Revision : 2
LAN MAC : 40A6B795C6AA
ETrackId : 80008942
PBA : K98023-005
VPD status : Valid
VPD size : 243
checksum : N/A
CIVD : 20.5.13
Vendor : 8086
Device : 1592
Subvendor : 8086
Subdevice : 000B
Revision : 2
LAN MAC : 40A6B795C6AB
ETrackId : 80008942
PBA : K98023-005
VPD status : Valid
VPD size : 243
checksum : N/A
CIVD : 20.5.13
Customer version : 0 I wasn't able to see the ETrackID 80008942 in the cfg included with the NVM update package, which I think is part of the issue.
Attached is the SSU for the system. I've also tried a few board partner update packages with the same result.
Guidance in completing the update would be appreciated.
Anyone that may land here in the future; it is possible to complete upgrades of this specific device using the Dell firmware DUP/update package. The key is that you have to run the .bin they provide for linux with --extract <dir>. Once the contents are accessible, you need to edit the .cfg files Dell provides to remove Windows carriage returns, else the config file will be malformed when running nvmupdate64e.
For whatever reason the dell wrapper refuses to identify their own cards when run directly, but with a linux compliant cfg file set, calling nvmupdate64e directly with their package contents works as expected, and the cards are properly flashed. This was accomplished under Debian 11 (Intel listed compatibility), specifically after adding the missing ddp non-free firmware package so the device fully boots and is not in safe mode.
-Boot Debian 11
-Compile oot driver that aligns with firmware
-Add ddp ice firmware package (Linux firmware)
-Add ddp comms firmware package (Linux firmware)
-modprobe -r ice; modprobe ice, check dmesg to be sure card is fully loaded and not safe mode
-execute Dell update package .bin with --extract
-edit nvminv.cfg and nvmupdate.cfg to be sure they're linux compiant/don't have windows newlines
-execute nvmupdate64e -c nvminv.cfg
At this point the upgrade should process. PAY ATTENTION to the finish output as it may direct you to reboot and directly run the updated again post reboot to complete the update. Failing to do so will leave the card in an Access Error state when you try to do the next level of NVM update!
This of course is not official advice, it is simply what worked in my case. Good luck other person who was likely sold this card as genuineintel, but in fact got a dell. I wasn't brave enough to try crossflashing, but if you are, leave a note on how it went.
Can you tell me what version you were going to? I am having a similar problem, I am at 3.00 and trying to get to 4.40
03) Intel(R) Ethernet 100G 2P E810-C 3.00(3.00) 1592 00:130 Update not
Adapter available
Tool execution completed with the following status: All operations completed successfully.
That's the version step I did. Started at 3.00 and went to 4.40. The key differentiator in my case was realizing that my card was not in fact genuine intel, but rather a dell version.
The giveaway was in the inventory output (-i -l) the subdevice and etrackID didn't match any entries in the nvm config from the Intel NVM updater package.
In my case,
Subdevice : 000B
Matches to the device definition in the Dell DUP Firmware updater pack. As mentioned in my earlier post, simply running the Dell utility as it comes from them (the .bin executable) ALSO failed for some inexplicable reason. Thus the extra --extract and then manual cleanup of the .cfg files, followed by running the extracted updater tool directly with -c
Hello Praxis,
Thank you for posting Ethernet Community. I'm here to follow up case as per subject. Appreciate you can advise on the issue happens after any BIOS/Firmware update. Please do confirm any latest hardware have been changed recently to lead this error.
For this matter, advise to check on the driver pack details as per below : Intel® Ethernet Adapter Complete Driver Pack
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days.
Thank you & Best Regards
Devi_Intel
Hello Praxis,
Regarding your community case posted, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution.
Thank you & Best Regards,
Devi_Intel
Hello Praxis,
Devi_Intel
Hello Praxis,
Devi_Intel
Hello Praxis,
Devi_Intel
