Ethernet Products
5742 Discussions
ESXI - LLDP Issues with Intel(R) Ethernet Controller E810-C for QSFP
RobWhite
Driver Info:
Driver: icen
Firmware Version: 2.15 0x800049c3 1.2789.0
Version: 1.5.5.0
OS Version:
VMware ESXi, 6.7.0, 17700523
I tried both the following commands and the protocol LLDP will not work. Verified that the connected switch is sending LLDP frames.
  • esxcli system module parameters set -m icen -p LLDP=0,0
  • esxcli system module parameters set -m icen -p LLDP=1,1
Any thoughts on what I should try next?
Mike_Intel
Hello RobWhite,
For us to further check the issue, please provide the following details.
  1. Are you using an onboard E810 or a PCIe card?
  2. Can you tell us why do you want to edit the LLDP settings?
  3. If you are using a PCIe E810, can you send a photo focusing on the markings of the card on both sides?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Mike_Intel
Hello RobWhite,
I hope you enjoyed your weekend. I am just making a follow up on the information that we requested for us to assist you.
Michael L.
Mike_Intel
Hello RobWhite,
I hope this message finds you well. I am just sending another follow up on the information that I requested. Since we have not heard back from you, I need to close this inquiry.
If you need further assistance, please post a new question.
Thank you and stay safe
Michael L.
