Ethernet Products
5736 Discussions
How can I configure the i210-T1 nic in order to enable AVB streaming in win10?
SKIOU
Hi Stamatiski,
Thank you for the post. You may refer to below link for the driver and sample application to configure AVB for I210
https://sourceforge.net/projects/e1000/files/linux_igb_avb/2.3/ https://sourceforge.net/projects/e1000/files/linux_igb_avb/2.3/
Rgds
wb
SKIOU
Thank you for your answer wb.
However this solution applies to a Linux installation, not for Windows which I asked for.
I am already using a small AVB network successfully. I am using an AVB switch and two external devices (a motu 112D and a DSP4YOU DG are part of this network).
I installed the latest drivers to i210-T1 and I am trying to test using the HONO AVB asio drivers but the i210-T1 is not recognized as an AVB device.
Perhaps the problem is elsewhere but I was wondering if there is some kind of special configuration regarding the NIC for Windows.
Many thanks again
Hi Stamastiski,
Thank you for the clarification. I will check on this.
rgds,
wb
Hi Stamastiski,
Further checking, in order to record AVB audio on Windows system, you need OS, driver and software that can support AVB. And driver/software support of AVB on Windows is only available through thirty party solution.
You may also refer to page 10 of FAQ website below:
http://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf
Please try contacting the driver developers as they have drivers run on Intel i210 Gigabit AVB NIC.
http://www.audioscience.com/internet/products/avb/hono_avb_vsc.htm
Hope the above information help.
Rgds,
wb
Hi Stamastiski,
Please feel free to update me if you still have other inquiries.
Thank you.
rgds,
wb
