Ethernet Products
5697 Discussions
How do we determine whether the link is forced enable or auto in intel DPDK VF PMD for X710 NIC ?
HCalc
Please consider this example of Intel X710 NIC with 1 VF connected to a centos VM and has all DPDK 19.11 pre-requisite installed.
Host Side : Intel X710 NIC ( i40e Kernel Driver )
VM Side : Intel X710 VF and DPDK Testpmd application.
Now, force enable the VF link on the host side by using ip link command,
# ip link set (Ethernet Device Name) vf (VF Number) state enable
On the VM side start testpmd application and check the port info as sh own below,
testpmd> show port info all
********************* Infos for port 0 *********************
MAC address: 32:41:32:DF:C0:D2
Device name: 0000:3b:0a.0
Driver name: net_i40e_vf
Connect to socket: 0
memory allocation on the socket: 0
Link status: up
Link speed: 40000 Mbps >>>>>>>>>>>>>>>>>>>>>>>> Link Speed : 40G
Link duplex: full-duplex
MTU: 1500
Promiscuous mode: disabled
Allmulticast mode: disabled
Maximum number of MAC addresses: 64
Maximum number of MAC addresses of hash filtering: 0
VLAN offload:
strip off, filter off, extend off, qinq strip off
Hash key size in bytes: 52
Redirection table size: 64
Supported RSS offload flow types:
ipv4-frag
ipv4-tcp
ipv4-udp
ipv4-sctp
ipv4-other
ipv6-frag
ipv6-tcp
ipv6-udp
ipv6-sctp
ipv6-other
l2_payload
Minimum size of RX buffer: 1024
Maximum configurable length of RX packet: 9728
Maximum configurable size of LRO aggregated packet: 0
Current number of RX queues: 1
Max possible RX queues: 16
Max possible number of RXDs per queue: 4096
Min possible number of RXDs per queue: 64
RXDs number alignment: 32
Current number of TX queues: 1
Max possible TX queues: 16
Max possible number of TXDs per queue: 4096
Min possible number of TXDs per queue: 64
TXDs number alignment: 32
Max segment number per packet: 0
Max segment number per MTU/TSO: 0
testpmd> quit
As seen from above the link speed is coming as 40Gig, for 10Gig Intel Adapter.
Can you please let us know how we can determine whether the vf link is currently auto, enable from VM perspective.
Thanks in advance.
AlfredoS_Intel
Hi Hcalc,
Since your inquiry involves DPDK, we have a different team who supports DPDK.
Please open the link below to log your inquiry.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html.
Click the "Login and Access" to contact the DPDK support
If you have questions, please let us know.
Alfred S
Intel Customer Support
HCalc
Hi Alfred,
Thanks, please note my query is not related to DPDK, however I am just using DPDK as a tool to show an issue. This can also be seen on Kernel driver.
