Ethernet Products
5736 Discussions
How to install 'Rivet_Networks_LLC-KillerNetworkComponent.inf'
ghjcfrt
Previous posts
I tried reinstalling, but the problem persists.
JedG_Intel
Hello ghjcfrt,
Since the issue persists, please share the information below.
1. Please share a screenshot of the error message:
2. Have you recently made any changes to your system configuration that might affect network drivers or software installations?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this a laptop or desktop system?
5. Did you have a previous version of the Killer Control Center installed, and if so, did it work correctly?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon.
Best regards
Jed G.
ghjcfrt
I haven't made any changes to my computer. My computer is a desktop PC that I built myself, so there is no such thing as an original adapter. It has always been this way.
I installed Killer Control Centre before, and it worked fine. I don't know the specific version, but it was the old UI version (as shown in the picture).
(Image sourced from the internet)
JedG_Intel
Hello ghjcfrt,
Thank you for sharing all this information.
To further troubleshoot the issue, please try to update your BIOS to the latest version F17a and let me know if the same issue will be observed.
If you have any questions, please let me know.
Best regards
Jed G.
ghjcfrt
I updated it, but the problem remains.
JedG_Intel
Hello ghjcfrt,
Thank you for your efforts. I will conduct an internal investigation into this matter and provide you with an update as soon as possible.
Best regards
Jed G.
JedG_Intel
Hello ghjcfrt,
I'm writing to give you an update about our investigation.
I checked the motherboard's specification and we can see that the motherboard does not come with an integrated wireless adapter. Therefore, it appears that you have self-installed the Killer Wi-Fi 6 AX1650x. We would like to highlight important guidance based on Intel’s article: Why Doesn't My Laptop Recognize My New Intel® Wireless Adapter?
Intel does not recommend installing or upgrading various Intel® Wireless Adapters on systems that were not originally designed to support them. This is due to several key reasons:
  • Compatibility Issues: Replacing an adapter that is associated with specific wireless software or drivers with a different adapter type may lead to connection problems or software error messages.
  • Regulatory Compliance: Wireless hardware installations or upgrades may violate regional regulatory requirements, especially if the system was not certified for the new adapter.
  • Long-Term Reliability: While the adapter may appear to work initially, over time, you may encounter intermittent issues, degraded performance, or system instability.
We recommend that you visit our Intel’s Regulatory Information Regarding Wireless Hardware Installation or Upgrade, which outlines the limitations and legal considerations of modifying wireless components.
For further assistance and to ensure full compatibility and support, please try contacting the motherboard manufacturer directly so they can provide guidance on supported wireless adapter upgrades and any available certified options.
Best regards
Jed G.
ghjcfrt
I do not believe this is my issue.
When I first purchased this network card, it was a relatively new model, and at that time I had successfully used the Killer Control Centre, rather than it being perpetually unusable.
Moreover, it's evident that “Rivet_Networks_LLC-KillerNetworkComponent.inf” is not a file the system or BIOS should provide natively, but rather a driver file. Yet when I installed the driver specified by the "
Intel® Driver & Support Assistant", the Device Information File was missing.
If your Killer Control Centre no longer supports older network cards, please state this clearly, or provide an older version of the Killer Control Centre.
I don't think it's particularly productive to say this to customer service, but your user experience has been dreadful these past two years. I've used different Killer network cards across various computers and operating systems, and each time you've blamed the issue on the OEM or motherboard compatibility. To put it bluntly, sometimes the system works better without the driver installed. In fact, most gaming optimisers actively block Killer's services to improve game performance and network stability. Your Killer's supposed focus on gaming is a joke. If it's not up to scratch, scrap the product line.
JedG_Intel
Hello ghjcfrt,
I truly understand how you feel, and I want to sincerely apologize for any inconvenience it has caused you. Your experience matters to us, and I’m committed to exploring all possible options or workarounds that could help resolve this issue.
Best regards
Jed G.
JedG_Intel
Hello ghjcfrt,
Thank you for your patience while we looked into this matter. We’d like to share that Intel follows local laws wherever its products are used. Because of country-specific regulations, Intel does not support installing non-desktop wireless cards on your own.
For wireless integration, we recommend reaching out to your motherboard manufacturer. Each country may have different rules, so before installing or replacing an Intel® Wireless Adapter, it’s important to confirm with the system manufacturer that the adapter is approved for use in your system and location. You’ll also need to follow any requirements they provide after approval.
If the manufacturer hasn’t secured the necessary approvals, the responsibility falls on the installer. Please note that installing adapters in systems without proper authorization may be against the law. Only the manufacturer or an authorized representative is allowed to perform the installation.
About the error message that you encountered, we see you are using an older version of the Killer Control Center. To further troubleshoot the issue, you may check our article: How to Perform a Clean Installation to Solve Most Intel® Killer™ Performance Suite Issues.
As for your question about Killer Card performance with game optimizers, we suggest starting a separate thread so we can focus on that topic more effectively.
We’re sorry for any inconvenience this may have caused, and we’re here to help if you have any further questions.
Best regards
Jed G.
JedG_Intel
Hi ghjcfrt,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
JeanetteC_Intel
Hello ghjcfrt
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
carecynthia
Same problem here, only that I wasn't using a self-built desktop, but a pre-built laptop. No hardware configuration at all, the same laptop I've been using for years.
A few months ago, after a regular update received from the "Intel® Driver & Support Assistant", the Killer Control Center stopped working due to "service not running". Not like it was the first time anyway. I waited for some follow-up updates to solve the issue by itself, but it never did.
Subsequently I tried to uninstall & reinstall the Killer Performance Suite as your site suggested, only to realize no longer any "service" related to Killer is installed in the service.msc anymore, no matter how many times I tried (yes using administrator permission, close every other app, relaunch and such).
Today I tried to also uninstall the Killer Control Center and the drivers as well. The drivers were reinstalled automatically; however, the Killer Control Center was unable to be reinstalled due to lacking 'Rivet_Networks_LLC-KillerNetworkComponent.inf' of error code "0x803FB005".
Doesn't seem like a problem related to the motherboard to me.
I_Nawf
It could be caused by broken dependency in the Killer Control Center installer. You’ll need to manually install the required driver before reinstalling the Control Center.
Cheers
carecynthia
Makes sense.
Although I have no idea where to find 'Rivet_Networks_LLC-KillerNetworkComponent.inf'. This thread and a few less informative ones are the only places I could find ever mentioning it.
Thanks for the reply anyway.
carecynthia
Makes sense.
