Ethernet Products
5821 Discussions
I210/I225 eeupdate64e to blink port LED, no GUI
Heitor
Dear Intel team,
Before programming ports MAC for the first time, I need to use eeupdate64e tooling to make these LEDs blink to ensure that the NIC number refers to the physical port with the blinking LED.
I am using the version for Linux, and I can perform this by calling the GUI option and pressing 'b' after selecting the desired port. But I need to use it by calling by shell command line.
Could you let me know if there is any option as "./eeupdate64e /NIC=1 --blink"?
Rgds,
Heitor.
CarlosAM_INTEL
Hello, @Heitor:
Based on the provided information, we want to address the following questions to be on the same page with you:
Is your problem related to adding cards or NIC cards like the one described on the following website?
https://ark.intel.com/content/www/us/en/ark/products/68668/intel-ethernet-server-adapter-i210t1.html
In case your answer is affirmative, please let us know the manufacturers and part numbers of the cards related to your request.
Or, is your problem related to a board design made by you using the Intel® Ethernet Controller I210 or Intel® Ethernet Controller I225?
Where do you acquire the Intel® Ethernet Controllers for the affected designs?
We are waiting for your clarification.
@CarlosAM_INTEL.
Heitor
Hi @CarlosAM_INTEL ,
          The problem is related to :
           https://ark.intel.com/content/www/us/en/ark/products/211808/intel-ethernet-network-adapter-i225t1.html
          I have these Ethernet ports. Since I need to program their MAC's and that should depend on their physical location , I want to make a specific port blink, so you can know where your Ethernet port physically is on them machine before programing the first MAC address.
          Using the software ./eeupdate64e /GUI and selecting the port and pressing 'B' is possible, but I need to do it through a system call. Is that possible?
Heitor.
CarlosAM_INTEL
Hello, @Heitor:
Thanks for your reply.
Based on the provided information in your previous communication, could you please clarify the place of purchase of the Intel® Ethernet Controller I226-IT last listed by you?
We are waiting for your answer.
@CarlosAM_INTEL.
Heitor
HI @CarlosAM_INTEL ,
         I have added I226 by mistake and it is now removed.
Rgds,
Heito.r
CarlosAM_INTEL
Hello, @Heitor:
Based on your last communication.
Your consultations are related to Intel Ethernet Adapters.
We are going to transfer this forum to the proper channel support.
The person in charge of this channel will contact you as soon as possible.
@CarlosAM_INTEL.
