Ethernet Products
5868 Discussions
I210 vs. LAN7430
JakobZ
could you please help me choose between the I210 (I210-IT) and the LAN7430? What are the key differences and why should one be chosen over the other? Thanks in advance.
Best, Jakob
pujeeth
Hello JakobZ,
Greeting!!
Thank you for contacting Intel,
To ensure you select the most appropriate Ethernet solution for your environment, we recommend reviewing the product specifications of the Intel Ethernet Controller I210-IT. You can find detailed features and capabilities of this controller at the following official Intel webpage:
https://www.intel.com/content/www/us/en/products/sku/64402/intel-ethernet-controller-i210it/specifications.html
Additionally, we encourage you to reference the datasheet for comprehensive information about its technical specifications, performance attributes, and environmental suitability.
Kindly note that we are unable to provide a direct comparison between this products. However, we believe that evaluating the Intel I210-IT documentation will help you determine if it meets your environment.
Pujeeth
pujeeth
Hello JakobZ,
Greeting!!
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action we provided.
Pujeeth
JakobZ
Hello Pujeeth,
your plan of action is to check the datasheets which is exactly what I already did before this inquiry. I was hoping for additional support from your side with more in-depth knowledge of your own product to compare it to the Microchip one. We will continue by evaluating both chips on a devkit and rely on the Microchip support.
Best, Jakob
Sreelakshmi1
Hello JakobZ,
Thank you for your response.
We would like to inform you that the product specifications and features are determined based on the user's requirements and the intended purpose of the product.
As shared earlier, please refer to the datasheet of the Intel I210-IT for comprehensive details regarding its technical specifications, performance characteristics, and environmental suitability.
Thank you for understanding.
Sreelakshmi
pujeeth
Hello JakobZ,
Greeting!!
Pujeeth
pujeeth
Hello JakobZ,
Greeting!!
We are following up on this issue. Since we have not received a response, we will proceed with closing the case.
If you need any further assistance regarding this matter, please reply to this email. We will be happy to reopen the case or create a new one and continue supporting you.
Pujeeth
