Ethernet Products
I219 support
ServiceE2
I have a Dell 7680 with Intel Ethernet Connection (22) I219-LM.
When I install the lastest PROset version (28.3), it says that the card is not supported.
Refering to the README.pdf, it appears that Intel Ethernet Connection (20) I219-LM and Intel Ethernet Connection (24) I219-LM are supported.
Could you please confirm that PROset 28.3 does not support my card ?
If so, is there an older version that supports it ?
Otherwise, how can I configure VLAN on my card ? Going into the card advanced properties menu, I can see an option to set (or not) VLAN, so I assume VLAN ARE supported on this hardware.
Thanks for help,
Robert
Devi_Intel
Hello ServiceE2
Thank you for posting Ethernet Community. my sincere apologize on delay as we facing reply thru this thread and at last manage to follow this case. Appreciate you can advise the issue need to be monitor. for further concern please do let us know.
Thank you & Best Regards,
Devi_Intel
Hayat
Hello ServiceE2,
Kindly share with us few information as below:
  • Operating System name, build and version
  • Screenshot of Advanced properties menu
Kindly go thru below articles related to Proset as well to know more:
https://www.intel.com/content/www/us/en/support/articles/000005686/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
https://community.intel.com/t5/Ethernet-Products/Vlan-creation-intel-1219-v/td-p/1536691
Kindly let us know if you have any questions;
Hayat
Intel Customer Support
Hayat
Hi ServiceE2,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
Hayat
Hello ServiceE2,
Since there are no replies, we will proceed to close the thread.
Please be informed, once the thread is closed it will no longer be monitored by Intel.
Kindly open a new thread if you have further questions. We will be more than glad to assist you.
Hayat
