Ethernet Products
5867 Discussions
[I350-T4] (repost) Is it allowed us to use pps through SDP?
ymha
I have been using a system with Jetson Xavier AGX (developer kit board with ubuntu 20.04) and a NIC based on the Intel I350-T4 chipset. I would like to receive the reference schematic of the chipset, enable and capture pps (pulse per second) of the NIC, and test performance of the NIC for the IEEE 1588 synchronization.
Could you please provide information about the below?
- requirement for obtaining the schematic,
- support of a device driver of the Ubuntu 20.04 for the Jetson Xavier AGX for enabling pps of the NIC,
- and accessible physical pin(s) or pinmap to capture the pps (NIC product name: aswinipc LX4-350 based on the Intel I350-T4).
Thank you in advance.
Youngmok Ha
JunAn_Intel
Hello YMHA,
You may refer this link for the datasheet of I350 series:
https://www.intel.com/content/www/us/en/content-details/333171/intel-ethernet-controller-i350-datasheet.html
  1. For the schematic and pinmap, please refer this link below to post this question to embedded community
  2. https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
  1. To enable PPS (Pulse Per Second) on the NIC (Network Interface Card) of the Jetson Xavier AGX, you will need to install a device driver that supports PPS. One possible driver that you can use is the ptp_kvm driver, which is included in the Ubuntu 20.04 kernel.
 Since you mentioned this is a repost, I think the solution might provided from the previous communities post.
https://community.intel.com/t5/Ethernet-Products/I350-T4-Is-it-allowed-us-to-use-pps-through-SDP/m-p/1448536#M31924
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
JunAn_Intel
Intel Customer Support
JunAn_Intel
Hello YMHA,
I hope you're having a wonderful day. I am just sending a soft follow up to check if you still have questions or clarifications. We will wait for your reply.
JunAn_Intel
JunAn_Intel
Hello YMHA,
I hope you're having a wonderful day. I am just sending a follow up to check if you still have questions or clarifications. We will wait for your reply. As for now, we will be closing your thread.
Thank you.
JunAn_Intel.
