Ethernet Products
5734 Discussions
Intel 82579 Ethernet Controller And Bugcheck 9F Crash
I'm getting a crash when putting the computer to sleep. I'm using the latest drivers (16.2). Anyone else having this poblem or know of a solution? System details and memory dump details below:
Asus P8P67 Deluxe (Bios 1503)
Intel i7 2600k
Windows 7 x64 SP1
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\051911-17721-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?00000000`00000000?
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`041b13c0?
WARNING: Whitespace at end of path element
Symbol search path is: SRV*c:\websymbols*http://msdl.microsoft.com/download/symbols http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`02a1d000 PsLoadedModuleList = 0xfffff800`02c62650
Debug session time: Thu May 19 08:00:12.897 2011 (UTC - 5:00)
System Uptime: 6 days 16:01:36.553
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, fffffa8006cbe060, fffff800041b13d8, fffffa8007160910}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8006cbe060, Physical Device Object of the stack
Arg3: fffff800041b13d8, Functional Device Object of the stack
Arg4: fffffa8007160910, The blocked IRP
Debugging Details:
OVERLAPPED_MODULE: Address regions for 'hiber_iaStor' and 'hiber_iaStor' overlap
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7928f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000e0a000 pci
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
STACK_TEXT:
fffff800`041b1388 fffff800`02b099c2 : 00000000`0000009f 00000000`00000003 fffffa80`06cbe060 fffff800`041b13d8 : nt!KeBugCheckEx
fffff800`041b1390 fffff800`02aa8652 : fffff800`041b14c0 fffff800`041b14c0 00000000`00000001 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`041b1430 fffff800`02aa84f6 : fffff800`02c44f00 00000000`02337e05 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x66
fffff800`041b14a0 fffff800`02aa83de : 0000053d`544dea48 fffff800`041b1b18 00000000`02337e05 fffff800`02c12328 : nt!KiProcessExpiredTimerList+0xc6
fffff800`041b1af0 fffff800`02aa81c7 : 000001be`d04b10c1 000001be`02337e05 000001be`d04b1039 00000000`00000005 : nt!KiTimerExpiration+0x1be
fffff800`041b1b90 fffff800`02a94a2a : fffff800`02c0fe80 fffff800`02c1dcc0 00000000`00000002 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`041b1c40 00000000`00000000 : fffff800`041b2000 fffff800`041ac000 fffff800`041b1c00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0x9F_3_e1c62x64_IMAGE_pci.sys
Gaurav_E_Intel
It sounds like your system is not entering hibernate properly. It could be calling the driver to shutdown, but the driver may also be expecting the OS to call its sleep routine. There are a few tests to try:
1. Update the driver to 16.3...located here.. http://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18713 http://downloadcenter.intel.com/detail_desc.aspx?agr=Y&DwnldID=18713
2. Disable the LAN device and try to sleep.
3a. Setup your computer to disable hybrid sleep. You can follow this guide...http://maximumpcguides.com/windows-7/turn-off-hybrid-sleep-in-windows-7/ http://maximumpcguides.com/windows-7/turn-off-hybrid-sleep-in-windows-7/
3b. Then see if both Standby and Hibernate cause your system to BSOD, or just one of them.
4. Repair/Re-install your OS. Your pci.sys driver might be corrupted causing the OS to stall.
