Ethernet Products
Intel® Ethernet products and technologies
4265 Discussions
Intel Boot Agent ??
cdeco1
I had a virus.
I restored a backup computer D845PESV Windows XP Pro SP3.
My old backup was not my new PCI Ethernet card Intel PRO / 1000Mbps PCI ACPI, Wake on LAN, PXE.
She has been recognized and works very well.
I am still a problem at every boot I have ever had before, a DOS window that says:
Initialyze and etablishing link
Intel Boot Agent GE v1.2.22 DHCP
PXE-E53 No boot file
PXE-MOF Exiting boot
How to remove this procedure?
Thank you for your cooperation
st4
New Contributor III
Hi Decop,
What you can do is to disable the bootagent.
Download preboot.exe which contain the bootutil.exe utility.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19186 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19186
Create a bootable dos flash drive
Copy bootutil.exe in the drive
Boot from the drive to enter into dos mode,
execute the command bootutil -FD to disable the bootagent
example:
To disable the flash firmware on all the network adapters.
BootUtil -ALL -FD
You may refer more info on these websites
http://www.intel.com/support/network/sb/cs-008018.htm http://www.intel.com/support/network/sb/cs-008018.htm
http://www.intel.com/support/network/adapter/pro100/bootagent/sb/cs-008212.htm http://www.intel.com/support/network/adapter/pro100/bootagent/sb/cs-008212.htm
hope this helps.
wb
cdeco1
Hello!
Thank you for your reply.
I solved the problem with the BIOS \ boot \ Boot PXE LAN ds = Disabled
