Ethernet Products
5614 Discussions
Intel Corporation 82598EB 10-Gigabit AF Dual Port Network Connection (rev 01) supports FCOE
VRedd3
I have Intel X520 Card and i am trying to set it up open fcoe in Redhat 6.X host. I am unable to find wwpn number I am doubt whether my card supports is CNA capable that is it support fcoe or I need to load any drivers.
I have Intel x520 10 Gig card.
Below is the lspci output
0c:00.0 Ethernet controller: Intel Corporation 82598EB 10-Gigabit AF Dual Port Network Connection (rev 01)
0c:00.1 Ethernet controller: Intel Corporation 82598EB 10-Gigabit AF Dual Port Network Connection (rev 01)
0e:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
0e:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
Hi asteroid4u,
Thank you for the post. What is the serial number of you X520?
You may look for the complete serial# at the white sticker on the NIC itself.
Here is the website for your reference.
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007022.html
wb
VRedd3
Hi WB,
Thanks for reply. Below are the details
Its X520-DA2
9000139
E10G42BTDA
Hi asteroid4u,
Thank you for the information. The serial number looks different, can you please locate the serial number on the white sticker (with bar code) on the network adapter. The format goes like 15 digits + 5 digits + 6 - 3 digits.
The X520-DA2 is in the supported FCOE network adapter list
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006982.html
wb
VRedd3
Yes it is supported but it is not showing wwwp number is any driver needs to be install for FCOE?
Hi asteroid4u,
Please check on steps on page 2 of this guide to configure
http://www.intel.com/content/www/us/en/ethernet-products/converged-network-adapters/open-fibre-channel-over-ethernet-for-linux-based-eternet-server-adapter-x520-brief.html
Do you have the serial number of the network adapter?
wb
VRedd3
Hi Wb,
Its in remote location hence i am unable to get the serial # . I have asked remote admin to share the serial number and yesterday he have shared model numbers instead of serial number hence. I will requested again to share serial number and i have not got reply. I am waiting for reply.
By seeing exact model number in Intel website it concludes that it will support Fcoe.
Now I am hitting another problem. Modules not supported is any specfic model for this card?
ixgbe 0000:0e:00.0: PCI INT A -> GSI 28 (level, low) -> IRQ 28
ixgbe 0000:0e:00.0: setting latency timer to 64
ixgbe: 0000:0e:00.0: ixgbe_check_options: FCoE Offload feature enabled
ixgbe 0000:0e:00.0: failed to load because an unsupported SFP+ or QSFP module type was detected.
ixgbe 0000:0e:00.0: Reload the driver after installing a supported module.
ixgbe 0000:0e:00.0: PCI INT A disabled
Hi asteroid4u,
Thank you for the update and taking time to obtain the serial number.
Intel X520 series network adapter required the use of supported modules.You may refer to this website for the support modules, scroll down to refer to the table:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005688.html
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005528.html
Hope the above information help and clarified.
rgds,
wb
Hi asteroid4u,
Have you tried using the supported fiber modules and obtain the serial number?
rgds,
wb
VRedd3
Hi Wb,
Sorry I cannot able to get this serial number as this in Server and they are testing for other things. I dont have supported modules Is there any way i can mask this this supported modules check?
Hi asteroid4u,
Thank you for the update. I will check for you about the FCOE inquiry.
rgds,
wb
Hi asteroid4u,
Our X520 series network adapter used 82599 ethernet controller, but based on your output
it shows 82598EB ethernet controller, that is why I would like to know the exact serial number
to identify the NIC. You may refer to this link for the list of X520 showing 82599 as the ethernet controller http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005612.html
You may refer to the list of supported X520 series network adapter that supports FCOE which I provided earlier.
wb
Hi asteroid4u,
Good day. Any update for for identification of the network adapter ?
rgds,
wb
VRedd3
Hi WB,
Remote admin informed there may be sticker removed Is there any way we can pull out these info in linux OS like using dmidecode?
Hi asteroid4u,
Thank you for the reply. I don't have information using this command to obtain the serial number. We need to identify your network adapter correctly to better check on this.
thanks,
wb
