Ethernet Products
5740 Discussions
Intel E810-CAM1 network card Failure to issue "dmesg" command.
Tommy0923
Hi Sir,
I'm using an Intel 25G (E810-CAM1) NIC to test the dmesg commands for failure issues.
When the driver is installed, the error problem shown in the picture occurs whenever the {dmesg | grep -i "Failed to read "}command is reached under Linux.
Please help how to deal with this issue, thanks.
OS: Ubuntu 22.04.1 LTS (GNU/Linux 6.2.0-33-generic x86_64)
Driver ver.: ice-1.12.7
Sazirah
Hi Tommy0923.
Good day.
We received a request to close this case few days ago. Since you no longer require any assistance from our end, we will proceed to close this case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thank you.
Sazzy_Intel
