Ethernet Products
公告
5862 讨论
Intel Killer E3100X - TLS handshake failures on Ethernet only, recurring driver instability
MPCre
初学者
1,217 次查看
Hello, I’m experiencing a recurring and reproducible issue with the Intel Killer E3100X Ethernet Controller on Windows 11. The problem affects only the wired interface; Wi‑Fi works normally.
  • TLS handshakes fail on many websites when using Ethernet
  • Some HTTPS sites load, others fail consistently.
  • Switching to Wi‑Fi immediately resolves all issues.
  • The problem can appear suddenly during normal system use (not only after reboot).
  • Event Viewer shows repeated crashes of Killer‑related services:
    • Killer ProviderDataHelper Service – Stopped working
    • Killer Intelligence Center – Stopped working
  1. System boots normally; Ethernet works for a while.
  2. After some time, TLS handshake failures begin on Ethernet only.
  3. Reinstalling the Killer driver temporarily fixes the issue.
  4. After a reboot or some runtime, the issue returns.
What I have tried
  • Clean reinstall of the Killer Performance Suite. (Also running a completely fresh windows installation)
  • Clean reinstall using Drivers‑Only (no Control Center).
  • Full removal of Killer software, services, and folders.
  • Verified that Wi‑Fi works perfectly during failures.
  • Verified that the issue is not browser‑specific.
  • Verified that the issue is not router‑related.
  • Disabled all offloading features (LSO, TSO, checksum offload).
  • The issue appears to be driver‑layer instability: TLS failures occur only on Ethernet, and only when the Killer driver is active.
  • The fact that the issue returns during runtime suggests a service or NDIS filter is crashing or entering a degraded state.
  • A clean reinstall + reboot sometimes stabilizes the driver temporarily, but the issue eventually returns.
    Has anyone else tried this, and if so - does anyone have a solution for this?
0 项奖励
5 回复数
RandyT_Intel
主持人
1,169 次查看
Hi @MPCre,
Thank you for posting in the community. Please allow me some time to investigate this issue. I will reach out to you via email to obtain the necessary information, as certain details cannot be collected through the community thread to protect your system’s security.
Please expect an email from me shortly. Thank you for your understanding and patience.
Best regard,
Randy T.
0 项奖励
MPCre
初学者
1,148 次查看
Thank you very much. I will respond as soon as possible.
0 项奖励
homotechsual
初学者
990 次查看
Did you get any information / resolution on this - facing the same issue here.
0 项奖励
MPCre
初学者
664 次查看
Hi
Unfortunately no. My computer had a lot of other issues it turned out, so I decided to wait with this as the issue may have been related to other things in my case. Sorry, but they did tell me to start a new ticket if it continues, so if this is the top search result, you could add a new ticket and link it here? That may help others.
0 项奖励
CorradoBacchiocchi
初学者
59 次查看
I have exactly the same problem on my PC Clevo Recoil18 with Killer E3100X 2.5 Gigabit Ethernet Controller, driver version: 2.1.5.7.
Please, Intel, provide some help!
Corrado
0 项奖励
回复
