Ethernet Products
5880 Discussions
Intel(R) Ethernet Connection I219-LM This device cannot start. (Code 10)
C-Lee
Dear Intel Customer Support,
I have problem with ethernet on my lonovo  X260.
I've tried repeatedly to delete and install the driver but it still doesn't work
if I look at the event in the device manager it says something like this
I also sent the results of the SSU
Please help, because apart from using wifi, I really need an ethernet port too
Caguicla_Intel
Hello C-Lee,
Please provide the following information that would help us in checking your query.
1. When was the issue first encountered?
2. Is this a newly purchased laptop? If no, for how long did the Ethernet worked fine and are there any changes prior to issue?
3. We understand that this is an Ethernet controller that's embedded with Lenovo system. For Original Equipment Manufacturer(OEM) on-board Ethernet controller, we'd like to set your expectation that we have a limited support and it would be best if you can also get in touch with Lenovo for further support since they have customized drivers and software to enable or alter features on your system. They are in best position where you can seek assistance so you don’t lose features or customizations of the Ethernet controller.
List of System Manufacturers
https://www.intel.in/content/www/in/en/support/contact-intel.html?tab=system-manufacturers
Lenovo Support
http://support.lenovo.com/
4. Based on the SSU shared, the current driver version installed was 12.18.9.8 from 27.0 Intel driver package. With this, we'd like to check if you already tried manually installing the driver that can be obtained from your manufacturer?
5. Have you also tried performing Clean Driver Installation Guide for Intel® Ethernet Connections and use the driver from your manufacturer?
https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
C-Lee
1. this happened after I installed Windows 10 built 19043
2. No. previous versions of windows 10 had no problems, even when I was still using windows 7
3. I have tried but it didn't work until now
4. I have tried from lenovo and it never worked
5. I've tried but it doesn't work either
do you have an idea so that my laptop can activate the ethernet
Caguicla_Intel
Hello C-Lee,
Thank you for the swift response.
You may check and try the steps from link below for Code 10 Error in Device Manager for Intel® Ethernet Connection
https://www.intel.com/content/www/us/en/support/articles/000060145/ethernet-products.html
In case the issue still persists after trying out the steps mentioned, kindly contact your manufacturer for further assistance.
Lenovo Support
Feel free to let us know if you have questions or clarifications.
Awaiting to your reply.
Should there be no reply, we will follow up after 3 business days.
Crisselle C.
C-Lee
Thank you for the advice. I will try to do this step. but can't in the near future because currently there is a lot of work.
thanks for the support and time.
BR,
C-Lee
Caguicla_Intel
Hello C-Lee,
You're most welcome, it's been our pleasure helping you out!
Thank you as well for the swift response.
Since it might take some time to carry out the steps from the link shared, would you like us to make a follow up after a week or two?
If it will take longer than that, can you confirm if would it be okay to close this request? You may post a new question and use this thread as a reference in case you'll need further assistance in the future.
Crisselle C.
Caguicla_Intel
Hello C-Lee,
Good day!
This is just a follow up to check if you wish us to make a follow up after a week or two since it might take some time to carry out the steps from the link shared?
Awaiting to hear from you.
Should there be no reply, We will follow up after 3 business days.
Crisselle C.
C-Lee
sorry for late response
I think it okay to close this request. because until now I still can't decide when I will do all these steps
however I thank you very much for your attention and support. if I have done this step and still have problems. I will inform you again
BR,
C-Lee
Caguicla_Intel
Hello C-Lee,
No worries at all. Appreciate your effort in sending a reply.
Please be informed that we will now close this request as per your advise. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
In case the issue still persists after trying out the steps mentioned from Code 10 Error in Device Manager for Intel® Ethernet Connection, kindly contact your manufacturer for further assistance.
Lenovo Support
Thank you for choosing Intel and stay safe!
Crisselle C.
