Ethernet Products
5869 Discussions
Intel(R) Ethernet Controller (3) I225-V Cannot Start
exzell
Hi Intel team,
Hope you are having a great day.
I am currently facing an issue with my Ethernet adapter.
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Intel(R) Ethernet Controller I225-V
When being used on Windows 10.
I have the following Motherboard
PRO Z690-P DDR4 (MS-7D36)
Which is from MSI.
Intel® Ethernet Adapter Complete Driver Pack
I have downloaded the latest driver version.
I don't know what's going on, I've tried redownloading drivers, troubleshooting and none of it has worked, and I am just trying to see what is going on. If you could assist me that would be very much appreciated.
Please let me know if any additional information is required.
Thank you
n_scott_pearson
So here's the list of things that i saw in the report:
  1. Just saying, Intel recommends the use of Windows 11 with 12th gen processor-based systems.
  2. I cannot see a valid BIOS version indicator. You should, if you haven't before, upgrade the BIOS to the latest version available (7D36vAG). You can download it here: https://download.msi.com/bos_exe/mb/7D36vAG.zip.
  3. Did you install the Intel Chipset Device Software package first thing after installing Windows? If not, you should do so now. It is available for download here: https://download.msi.com/dvr_exe/mb/intel_chipset_adl_rpl.zip.
  4. Your Wireless driver is out of date. You can download the latest version from here: https://www.intel.com/content/www/us/en/download/19351.
  5. Your Bluetooth interface does not have the Intel driver installed for it. The Microsoft driver was associated with it, but failed to load (no surprise). You can download the latest version from here: https://www.intel.com/content/www/us/en/download/18649.
  6. The Specification for your motherboard (per identification, MS-7D36, provided above) lists it as having Realtek RTL8125BG networking. I am confused. If I am looking at the wrong board's specification, the BIOS link I provided above may not be correct. If this is the correct motherboard, however, this means that you have an add-in card that is providing the i225-V. Either way, it appears that the correct driver is installed. I can only suggest that you do a clean install of the driver per the process detailed here: https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html.
It that doesn't get you going, I defer to Intel Customer Support,
n_scott_pearson
We need more information.
Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
exzell
Thanks for replying! Here is the information that you asked for.
n_scott_pearson
exzell
Yogaeasvaran
Greetings Exzell,
Thank you for contacting Intel Customer Support.
We have received your request regarding the error code 10 issue on your ethernet products.
May I know if the issue is still persist?
Yogaeasvaran
Yogaeasvaran
Greetings,
Regarding your case, we are following up to find out 2nd time if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
Yogaeasvaran
Greetings,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Yogaeasvaran
