Ethernet Products
5891 Discussions
Intel(R) Serial IO SPI Host Controller - 54FB
BobbyWobbly
I have a problem, in device manger there is something not installed, I have downloaded and used the driver up software but it stays the same.
The drivers for this device are not installed. (Code 28)
Windows 11 will not update it, I have the driver files but it's not there any idea where I can find the drivers?
Thank you
LeonWaksman
In order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
Leon
BobbyWobbly
Hello Leon    ,
Here is the file you requested.
LeonWaksman
Hello @BobbyWobbly ,
From the information in the SSU report attached to your post, I can't find what is the model of your system/motherboard. I understand that it is a MSI board and I understand that the Chipset Driver was not installed. The Chipset Driver should be the first software installed after Windows installation. I suggest that you should look  in the MSI site for downloads page of your board. Download and install the Chipset Driver, reboot your computer and only then install other drivers (like IO Serial Driver).
Leon
vish1
Hello BobbyWobbly,
Greetings for the day!!
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had time to check and provide us an update.
Vishal Shet P
BobbyWobbly
Still in the same situation, but starting to feel it may be the finger print reader as thats the only thing I can find thats not working.
I will try to find a driver for the finger print reader and see what happens.
Bobby
vish1
Hello BobbyWobbly.
Greetings!!
Thank you for the update. Please keep us posted on the progress after trying the fingerprint reader driver.
If you need any assistance from our side.
Vishal Shet P
vish1
Hello BobbyWobbly,
We wanted to inquire whether you needed any further assistance.
Vishal Shet P
vish1
Hello BobbyWobbly,
Greetings!!
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Vishal Shet P
BobbyWobbly
I'm starting to understand, this is the biggest problem with cheap Chinese Notepads/Laptops is drivers. Drivers are probably available but finding them is impossible.
I had a drive fail and can not find the malefactor of the laptop so a little stuffed really.
BobbyWobbly
Sorry I should have added the laptop is a ANL5-N95 made by Unknown.
vish1
Hello BobbyWobbly,
Greetings!!
The white-label Chinese OEM does not provide dedicated drivers for this platform please do confirm once with OEM. The failure related to the Serial IO SPI Host Controller – 54FB may be causing the issue. We recommend installing the generic driver packs from Intel and verifying if the controller functions properly after installation.
https://www.intel.com/content/www/us/en/support/articles/000005533/software/chipset-software.html
Note
If you purchased a pre-built system or third-party motherboard, contact your manufacturer for the latest updates and technical support information.
Vishal Shet P
vish1
Hello BobbyWobbly,
Vishal Shet P
vish1
Hello BobbyWobbly,
This is the follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
Vishal Shet P
