Hi, We are having some issues with the Intel X550 ethernet network and auto-negotiation of 5 Gbps.
The 4.1.197 driver does not show 5 Gbps in the advanced driver options, but if you select auto-negotiation it works at this speed.
Drivers 4.1.239 and 4.1.246.2 show 5 Gbps in the advanced driver options, but if you select auto-negotiation, it works at 1 Gbps, you must select 5 Gbps manually.
Is it normal or could it be fixed in newer drivers?
Thank you so much.
Hi Jorge_S,
Good day and thank you for reaching out to Intel Community Support.
The drivers that you are running for the NIC is quite old and we highly recommend that you use our latest drivers to avoid any bugs or software issues. Refer the link below for the latest drivers of the Intel X550:
Also, may I know if the NIC card is from an OEM manufacturer? You may provide the picture of the NIC for us to verify if the card is an OEM or not.
Let us know if you have any further questions.
Faez_Intel
Hi Faez,
I'm using the latest drivers, from driver pack 28.1.1 I'm getting Windows 10 version 4.1.246.2, it is in:
\PROXGB\Winx64\NDIS68\ixs68x64.inf
There are two Intel X550 on a Asus Pro WS WRX80E-SAGE SE WIFI motherboard and the hardware id is:
VEN_8086&DEV_1563&SUBSYS_87121043
The only solution I found is to install an old driver, version 4.1.197.
Thanks!
Hi Jorge_S,
Good day. This is just a follow up on the thread. Please let us know if you have any further questions and we will gladly assist you accordingly.
Faez.
Intel Customer Support
Hi Jorge,
Good day. Thank you for the clarification.
Since the NIC is an onboard for an OEM manufacturer, we highly recommend that you check with the OEM support. This is due to the firmware that are released by the OEM are customized to run on those boards and to use their own drivers and firmware instead of using Intel generic driver.
Kindly let us know if you have any other questions.
Faez_Intel
Hi Jorge_S,
Faez_Intel
Hi Jorge_S,
I hope you're having a wonderful day. I am just sending a follow up to check if you still have questions or clarifications. As for now, we will be closing your thread.
If you want to continue support, please reply to this community thread and we will reopen your case or create a new one so that we can continue to support you.
Faez_Intel
