Ethernet Products
5821 Discussions
Intel X710 Controller for 10GBASE-T in recovery mode with status "RECOVERY not available"
johntitor2036
So I have a server from LambdaLabs that contains an Intel X710 Controller for 10GBASE-T that had stopped working as intended. It is currently running Ubuntu 22.04. Troubleshooting led me to find in the following in dmesg:
i40e 0000:02:00.0: Firmware recovery mode detected. Limiting functionality.
After discovering this, I went here to see what I needed to do. Since the only info relevant there was to reprogram it I went and got the NVM utility for the 700 series from the download site. I also got the boot image utility from here as well. For the boot utility I also was able to copy the necessary files via USB to get the iqvlinux driver installed. Running the nvmupdate64e and the bootutil64e utility resulted in the following output, and I apologize for using an image, there isn't internet access on the server and I am currently unable to rerun these commands and redirect their output to a file and copy them via usb to copy and paste here:
In the provided ZIP file for the nvm tool there is multiple .bin files for X710 controllers, but I do not think any of them work for my controller. I was able to get this output as well:
The X710 .bins I have are:
X710-AT2_9p54_CFGID14p3.bin
X710-AT2_9p54_CFGID14p3_NCSI.bin
X710DA2_4p42_CFGID7p2_OEMGEN.bin
X710DA2_9p54_CFGID7p2_J51959_Retail_8M.bin
X710DA2_9p54_CFGID7p2_J83813_OEMGEN_8M_Type1.bin
X710DA2_9p54_CFGID7p2_OEMGEN.bin
X710DA2_9p54_CFGID7p2_OEMGEN_K97470.bin
X710DA2_9p54_CFGID7p2_OEMGEN_OO.bin
X710DA2OCP3_9p54_CFGID7p2_OEMGEN_K97342.bin
X710DA2OCP3_9p54_CFGID7p2_OEMGEN_OO.bin
X710DA2OCP_9p54_CFGID7p2_RETAIL.bin
X710DA4_4p42_CFGID7p2_OEMGEN.bin
X710DA4_9p54_CFGID7p2_OEMGEN.bin
X710DA4_9p54_CFGID7p2_OEMGEN_J38273.bin
X710DA4_9p54_CFGID7p2_OEMGEN_OO.bin
X710DA4FH_4p42_CFGID7p2_OEMGEN.bin
X710DA4FH_9p54_CFGID7p2_OEMGEN.bin
X710DA4FH_9p54_CFGID7p2_OEMGEN_OO.bin
X710DA4OCP3_9p54_CFGID7p2_OEMGEN_OO.bin
X710-DA_OCP3_EEPROM_MAP.txt
X710_T2L_9p54_CFGID14p3_OEMGEN_K29823.bin
X710_T2L_9p54_CFGID14p3_OEMGEN_K31193.bin
X710_T2L_9p54_CFGID14p3_OEMGEN_K87346.bin
X710_T2L_9p54_CFGID14p3_Retail_K37379.bin
X710_T2L_9p54_CFGID14p3_Retail_K58515.bin
X710T4_9p54_OEMGEN.bin
X710_T4L_9p54_CFGID14p0_OEMGEN_K29826.bin
X710_T4L_9p54_CFGID14p0_OEMGEN_K35334.bin
X710_T4L_9p54_CFGID14p0_OEMGEN_K92891.bin
X710_T4L_9p54_CFGID14p0_Retail_K37380.bin
X710_T4L_9p54_CFGID14p0_Retail_K58564.bin
X710-TM4_9p54_CFGID14p0_2BT_2BP.bin
X710-TM4_9p54_CFGID14p0_NCSI_2BT_2BP.bin
X710-TM4_9p54_CFGID14p1.bin
X710-TM4_9p54_CFGID14p1_NCSI.bin
X710-TM4_9p54_CFGID14p1_SMBus.bin
X710-TM4_9p54_CFGID14p2_4BT.bin
X710-TM4_9p54_CFGID14p2_4BT_NCSI.bin
What can I do about that "RECOVERY not available status"? Is it recoverable? Is there any firmware I can use here that I can try and use the nvm utility to reprogram the NIC or be provided to use? I would greatly appreciate any help here.
DisplayName123
I am curious too about intel support. Is it a 4x 10GbE card?
For me give me a lspci -n and dmesg | grep (ur driver/module)
johntitor2036
It is an onboard NIC with dual 10GbE ports/interfaces with a third for IPMI. Due to certain circumstances I am unable to get to my server at the moment for the exact command output, but I do have a picture of a lspci -v output of the NIC:
DisplayName123
To get network available if u have a free PCIe slots add another card, and assign addresses to this card.
for ur problem:
What was the reason to stuck card to Recovery mode ?
lspci -n
dmesg | grep i40e
modinfo i40e
./nmvumpdate -l
ip a | grep -v inet (i dont need ur ip addresses)  or u can use ip link show
foreach port:
ethtool -m Interface name for example  (for example ethtool -m eth0)
ethtool interface name (for example ethtool eth0)
Give me a photo of the labels of ur card.
