Ethernet Products
5868 Discussions
Intel X710 Dual 10G Receive Throughput Limitation During Simultaneous Recording
Abdul123
Hi Intel Team,
I am using the Intel Ethernet Network Adapter X710 NIC card with 4x10G Ethernet ports.
Current behavior:
  • When I receive and record a single 10G channel, I achieve around 1200 MB/s, which is expected and close to line rate.
  • However, when I simultaneously use two 10G channels for receiving and recording, the total throughput reaches only around 1600 MB/s.
Expected behavior:
  • Since I am using dual 10G links simultaneously, I expect combined throughput close to 2400–2500 MB/s total.
Environment:
  • CentOS 9 Linux
  • High-speed Ethernet data receiving and recording
  • NVMe SSD storage
  • Multi-threaded application
Please suggest:
  • Whether this limitation could be related to PCIe bandwidth, NUMA configuration, CPU bottleneck, RSS/queue configuration, memory bandwidth, or driver limitations.
  • Recommended driver settings and performance tuning for achieving full dual-port 10G receive throughput.
  • Best practices for queue/core mapping and RSS configuration with the Intel X710.
vish1
Hello Abdul123,
Greetings!!
We would like to inform you that the Intel Ethernet Network Adapter X710, particularly in configurations such as the Intel Ethernet Network Adapter X710-DA2 and Intel Ethernet Network Adapter X710-DA4, may experience inconsistent throughput when operating with Single Root I/O Virtualization (SR-IOV) interfaces.
In certain environments, especially during throughput testing on OpenStack virtual machines, performance may fluctuate between the maximum theoretical throughput and values as low as 1 Gbps. This behavior can become more noticeable during simultaneous operations and may result in limitations in receive throughput.
For your reference, we have shared a document that provides detailed information on advanced settings and Receive Side Scaling (RSS) for Intel® Network Adapters. These configurations may help in optimizing performance and improving consistency.
https://www.intel.com/content/www/us/en/support/articles/000005593/ethernet-products.html
https://www.intel.com/content/www/us/en/support/articles/000006703/ethernet-products.html
Please review the attached document and let us know if you require any further assistance.
Vishal Shet P
vish1
Hello Abdul123,
Greetings!!
We are following up on your case and wanted to check if you had a chance to review our previous email.
Please let us know if you need any further clarification or assistance. We look forward to your update.
Vishal Shet P
