Ethernet Products
4919 Discussions
Intel XL710 40G + QSFP+ AOC/DAC-cables - very high latency
cubewerk
We have 3 high-performance cluster-nodes directly connected via broadcast bond (Proxmox Linux, Kernel 5.15.35-2)
Server 1 -> Server 2
Server 2 -> Server 3
The directly connected setup works flawlessly on other clusters with 10G SFP+. The new QSFP+ 40G direct links however have a very high latency. Bond setup is simple:
iface bond0
inet static address 172.16.0.5/24
5.255.0 bond-slaves enp132s0f2 enp132s0f3
bond-mode broadcast
bond-miimon 100
Test-Results:
10G SFP+:
84:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
84:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
PING 172.16.2.103 (172.16.2.103) 56(84) bytes of data.
64 bytes from 172.16.2.103: icmp_seq=1 ttl=64 time=0.049 ms
64 bytes from 172.16.2.103: icmp_seq=2 ttl=64 time=0.056 ms
64 bytes from 172.16.2.103: icmp_seq=3 ttl=64 time=0.056 ms
64 bytes from 172.16.2.103: icmp_seq=4 ttl=64 time=0.054 ms
64 bytes from 172.16.2.103: icmp_seq=5 ttl=64 time=0.063 ms
64 bytes from 172.16.2.103: icmp_seq=6 ttl=64 time=0.053 ms
64 bytes from 172.16.2.103: icmp_seq=7 ttl=64 time=0.062 ms
64 bytes from 172.16.2.103: icmp_seq=8 ttl=64 time=0.071 ms
64 bytes from 172.16.2.103: icmp_seq=9 ttl=64 time=0.104 ms
64 bytes from 172.16.2.103: icmp_seq=10 ttl=64 time=0.063 ms
40G QSFP+ AOC (we tested QSFP+ DAC and AOC cables with same results)
21:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
21:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
PING 172.16.0.6 (172.16.0.6) 56(84) bytes of data.
64 bytes from 172.16.0.6: icmp_seq=1 ttl=64 time=1.08 ms
64 bytes from 172.16.0.6: icmp_seq=2 ttl=64 time=0.638 ms
64 bytes from 172.16.0.6: icmp_seq=3 ttl=64 time=0.628 ms
64 bytes from 172.16.0.6: icmp_seq=4 ttl=64 time=0.609 ms
64 bytes from 172.16.0.6: icmp_seq=5 ttl=64 time=1.31 ms
64 bytes from 172.16.0.6: icmp_seq=6 ttl=64 time=1.30 ms
64 bytes from 172.16.0.6: icmp_seq=7 ttl=64 time=1.31 ms
64 bytes from 172.16.0.6: icmp_seq=8 ttl=64 time=1.06 ms
64 bytes from 172.16.0.6: icmp_seq=9 ttl=64 time=1.32 ms
64 bytes from 172.16.0.6: icmp_seq=10 ttl=64 time=1.33 ms
As one can see, the latency is horrible via 40G QSFP+. Any ideas? Any help is greatly appreciated.
Thank you.
cubewerk
Our customer already switched to a different product and does not have the hardware anymore.
Caguicla_Intel
Hello cubewerk,
Thank you for the response.
We do understand where you are coming from and we sincerely apologize for the delay on this request.
Currently we are actively making a follow up to our engineers and waiting for their feedback. Unfortunately, we still do not hear anything from them reason why we can't share any progress regarding the investigation.
We will make another follow up on this request and rest assured that we are communicating all your feedback to them.
Thank you for your kind cooperation.
Crisselle C.
Intel Customer Support
Caguicla_Intel
Hello cubewerk,
Good day!
Please be informed that we are still waiting for the feedback from our engineering team. Rest assured that we will send another update within 3 business days for the status of this request.
Crisselle C.
Caguicla_Intel
Hello cubewerk,
I hope you're doing good!
We'd like to inform you that we still haven't received any update from our engineers. Rest assured that we are closely monitoring this request and get back to you no later than 3 business days.
Thank you for your kind understanding.
Crisselle C.
cubewerk
Crisselle,
it looks like this has no priority to your engineers. So please just be honest, if this will be solved or not, so we can move on and look for another vendor.
We need a solution!
Caguicla_Intel
Hello cubewerk,
We sincerely apologize on this matter as we are still waiting update from our engineering but rest assured that we are monitoring this request. We will get back to you as soon as we hear feedback from them.
Crisselle C.
cubewerk
Crisselle,
you dont have to aplogize over and over again if nothing changes. Just get back to us if you have a news from your engineers.
Caguicla_Intel
Hello cubewerk,
Appreciate your reply.
We will take note of your request and rest assured that we are closely monitoring this request then give you an update once we heard from our engineers.
Crisselle C.
Caguicla_Intel
Hello cubewerk,
I hope this message finds you well!
Please be informed that engineering is still checking your request and they would like to get more information for them to further validate.
Engineering is requesting the output from the following for both of the 10G and 40G configurations:
ethtool devname
ethtool --show-fec devname
ethtool -m devname
Awaiting to your reply.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Hello cubewerk,
Good day!
This is just a follow up to check if you read our previous message. If yes, please confirm and provide the information we request. In case you need more time on this, please advise and we will adjust our next follow up.
ethtool devname
ethtool -m devname
Hoping to hear from you soon.
Crisselle C.
cubewerk
