Ethernet Products
5737 Discussions
MAC update procedure for WGI210AT
KalyanGE
WGI210A Ethernet controller is being used on our custom CPU base board and Ethernet controller on based board is connected to Kontron CPU (Intel atom based SOM module) through PCIe.
We are using RTOS (VxWorks) on Kontron CPU module.
When we are trying to attach the device driver to the controller as a PCIe device. It is found that device has been not programmed in factory and later: its PCI device ID is 0x1531 instead of 0x157B according to I210 specification update (§Table 1-2 Device IDs).
The datasheet, specification update and FAQ docs precise a PCI device ID 0x1531 means “blank flash device”, “Not programmed/factory default” or “hardware default, indicating an unprogrammed device”
So we patched the device driver to support the Ethernet controller to solve temporarily the attachment issue and make it available. Nevertheless, the MAC Address is not configured (00:00:00:00:00:00) and other parameters could be not configured as expected.
Need support and process details to configure the MAC address on Ethernet chip.
Schematic reference :
Block Diagram :
  • Which tool needs to be used to program Flash memory / iNVM ?
  • What file to be programmed into the flash memory for  MAC address modification ?
  • Which programmer and software tool to be used to program the Controller or the flash Memory.?
  • In document 513655, there are many files. Which file needs to be used in iNVM?
IntelSupport
Community Manager
HI KalyanGE,
Greetings from Intel Support team.
Hope you are doing well.
Based on your inquiry, we see that you are using the custom PCB and trying to change the MAC address. We have specific forum for these issues.
Kindly use the below link and submit your request.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Mohammed Ali CM
ManoranjanDas
Hello KalyanGE,
Greetings!
Before we proceed, let me clarify if you are designing a system with an embedded i210 network card.
Please find the below link: https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products.
If you have questions, please let us know. In case we do not hear from you, we will follow up after 3 working days. Thank you.
Manoranjan.
KalyanGE
Hello Manoranjan,
We have custom PCB board designed (Control board for our X-ray based system) with Ethernet controller IC (WGI210AT).
N Kalyan Kumar.
KalyanGE
Adding block diagram with additional details and PCB images for reference.
N kalyan kumar
IntelSupport
Community Manager
HI KalyanGE,
Mohammed Ali CM
ManoranjanDas
Hello KalyanGE,
Greetings for the day!
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Manoranjan.
ManoranjanDas
Hello KalyanGE,,
Greeting for the Day!
We are currently awaiting your response regarding the case. If you have any queries or require further assistance, please feel free to respond on the community post. We are more than happy to assist you.
Thank you for choosing Intel products and services.
Manoranjan Das.
Subhashish
Hello KalyanGE,
Greetings!
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Subhashish_Intel
KalyanGE
Hello Subhashish,
As I was instructed to post the matter in a different forum, I initiated a different case in a specific embedded connectivity forum.
N Kalyan kumar
ManoranjanDas
Hello KalyanGE,
We appreciate your response to the case. we will proceed to close this case. If you find that you still required assistance, we kindly request you to respond to the case. This will allow us to either reopen the current case or initiate a new one, ensuring that we can continue to provide you with the required support.
Thank you for using Intel products and services.
Manoranjan.
