Ethernet Products
5740 Discussions
Modem Network interface Galileo
TUtt
Hi, i cant get my modem to pop up as a Network interface on my Galileo.. Any suggestions on what to do?
Galileo gen2
Modem : Telit he910
SD-image: Intel Yocto
Sergio_A_Intel
How are you connecting your router to the Galileo? What cable and ports are you using? You also need to have enabled the driver for the modem. Look for the driver of your specific modem. If you have it loaded you can check it with lsmod http://linux.about.com/library/cmd/blcmdl8_lsmod.htm lsmod - Linux Command - Unix Command . If you don't have it loaded you'd have to enable it manually. Take a look at http://alextgalileo.altervista.org/blog/reconfiguring-linux-kernel-adding-drivers-galileos-linux-image/ Reconfiguring Linux kernel and adding drivers into Galileo's Linux image
Sergio
