Ethernet Products
5764 Discussions
OptiPlex 5050 PC cannot recognize the NIC card PE210G2SPI9A
wxhou
I have a PC, OptiPlex 5050 x64-Based, model OWWJRX, version A00. Also I have a NIC card PE210G2SPI9A. I installed the Intel Driver & Support Assistant. The PC failed to recognize the NIC. I downloaded Release_30.5.zip driver and ran the APPS/SETUP/SETUP/Winx64/SetupBD.exe. The message says "Drivers for Intel Network Connections were successfully installed." However, Device Manager says the "Windows was unable to install your Ethernet Controller". Any help will be greatly appreciated.
MACM
Hi wxhou,
Greetings of the day.
Hope you are doing great.
Could you please share us the below details.
1) Please let us know if the adapter came along with the system or was purchased separately.
2) Please share us the front and back picture of the NIC adapter.
We will proceed further accordingly once we get the above information.
Mohammed Ali CM
wxhou
The card was purchased separately. Attached are the pictures of front and back of the card.
Akshaya1
Hi wxhou,
Thank you for sharing the image.
Upon reviewing the image, we noticed that you are not using an Intel-authorized NIC. Therefore, we recommend reaching out to the place of purchase for further assistance.
Please let us know if you need any further clarification.
Akshaya
