Ethernet Products
5736 Discussions
PTP v2.1 over PRP
Aleks007
Hi folks,
Does anyone know for sure the way plumbing shall be done in case of PTP on top of PRP, specifically:
- shall slave OC have one port or tow ports with 2 TSU and one PHC ? cant find any passage in the specifications
- Do PRP's port A and port B have some PTP identification? (BC, TC)
- Does presence of BC in PTP path between GMC and OC with PRP support actually creates a problem with RCT?
Are there any commercial solutions on the market for slave OC with PRP?
Thanks in advance,
Alex
Vik3
Hello Aleks007,
Thank you for posting on Intel Community. To assist you further, please provide the additional details below,
  • Please let us know which product you are using.
  • Kindly provide the SSU logs for further analysis.
Refer the article : Help Guide for the Intel® System Support Utility
Vikas_Intel
Vik3
Hello Aleks007,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
Vikas_Intel
