Ethernet Products
5732 Discussions
Problem with assign SR-IOV Intel NIC to QEMU Virtual Machine.
eenig
I am using an Intel 82599 NIC and would like to use the SR-IOV function to assign the virtual functions to my virtual machine. I actually follow the on-line Intel document to add the "max_vfs=2" parameter when the ixgbe module is loaded. I can see the virtual function of NIC by now:
[root@vt-host2 enigmaLi@vt-host2]# lspci
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller # 1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 05)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI # 2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI # 1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C220 Series Chipset Family H81 Express LPC Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 8 Series/C220 Series Chipset Family 4-port SATA Controller 1 [IDE mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
00:1f.5 IDE interface: Intel Corporation 8 Series/C220 Series Chipset Family 2-port SATA Controller 2 [IDE mode] (rev 05)
01:00.0 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection (rev 01)
02:10.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
02:10.1 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
02:10.2 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
02:10.3 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
and the "ip link show" gives me following result (I remove the kernel module ixgbevf):
[root@vt-host2 enigmaLi@vt-host2]# ip link show
1: lo: mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eno1: mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether e0:3f:49:4b:c1:82 brd ff:ff:ff:ff:ff:ff
13: virbr0: mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
link/ether 52:54:00:2b:19:36 brd ff:ff:ff:ff:ff:ff
14: virbr0-nic: mtu 1500 qdisc fq_codel master virbr0 state DOWN mode DEFAULT group default qlen 1000
35: enp1s0f0: mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 90:e2:ba:46:0a:30 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 1 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
38: enp1s0f1: mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 90:e2:ba:46:0a:31 brd ff:ff:ff:ff:ff:ff
But when I try to assign the virtual function(PCI dev assign) to my virtual machine, the virt-manager gives me following error:
Error starting domain: internal error: qemu unexpectedly closed the monitor: 2016-08-26T15:39:40.880928Z qemu-system-x8...
Hi enigma_lee,
I will further investigate on this issue and update you.
rgds,
wb
Hi enigma_lee,
Can you help provide further info using the ethtool -i output for us to identify the PF and VF driver loaded and the Linux OS version.
wb
HI enigma_lee,
Can you provide the information requested on my previous post?
thanks
wb
Waseem_A_Intel
Intel Xeon E3-1200 v3/4th Gen Core Processor lacks necessary features to support SR-IOV use case. Intel Xeon E5 Processors are recommended for SR-IOV use case.
