Ethernet Products
5821 Discussions
Program i225 on aarch64 platform
systel-sgidel
I have an i225 controller designed into my carrier board with an arm64 CPU (Nvidia jetson)
How can I load the firmware? Other users have asked and it does not seem there is an arm64 version of lanconf or eeupdate on the CNDA site and an intel rep emailed them directly.
I tried using the eeprom access tool and NVM 1.93 firmware files, but it doesnt seem to load the right image, and dumping the image does not match the firmware file at all.
When the board is rebooted, the igc driver complains the NVM image is invalid.
[   12.533280] igc 0001:01:00.0: Adding to iommu group 7
[   12.533636] igc 0001:01:00.0: enabling device (0000 -> 0002)
[   12.615440] igc 0001:01:00.0: The NVM Checksum Is Not Valid
[   12.868148] igc: probe of 0001:01:00.0 failed with error -5
Edit: I figured it out. It needed a full power cycle. I would delete this post but it doesnt look like I can
B_Y
Hi @systel-sgidel,
We're glad that you found out the resolution.
Please be informed that we will now close this request since issue resolved. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
In case you still have inquiry within inside Intel Communities you may post it to a forum as per link below.
Embedded Connectivity Forum:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Thank you.
BY_Intel
Intel Customer Support
