Ethernet Products
5737 Discussions
Query regarding WGI210IT ethernet controller
nitinyadav
Hi intel team
We are working with WGI210IT and we have a doubt regarding differential clock input of ethernet controller. Do the clock input have internal termination, if yes then what is the value of termination resistor and do the input support internal common mode or we have to provide external common mode. We are using this with a PCIe switch which is generating a LVDS clock out for endpoints, so to use this clock as an input do we have to provide an external common mode or we can directly give an ac coupled input to the clock input pins.
B_Y
Hi @nitinyadav,
May I suggest you to consider following suggestion:
First, you can refer the following public articles to locate the information you need:
- Intel® Ethernet Controller I210 Datasheet , example-page 25:
https://cdrdv2-public.intel.com/333016/333016%20-%20I210_Datasheet_v_3_7.pdf
https://cdrdv2-public.intel.com/327935/327935-Intel%20Ethernet%20Conroller-I210-product-brief.pdf
If the information is insufficient to resolve your uncertainty, kindly reach out to Intel Premier Support (IPS) to get support on design inquiries related to Intel network controllers.
Steps on How to Register and have Access to Intel® Premier Support:
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Alternatively, you may proceed to post a question on Intel Embedded Communities.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you.
BY_Intel
Intel Customer Support
