Ethernet Products
5685 Discussions
WGI210 MAC setting
netkerlQuevedoyat
Hi intel,
I designed H/W with WGI210AT which is configured with the NVM interface H/W connection with  MX25L4006 serial flash memory.
I designed interfaces with SM Bus for these four WGI210AT which are connected to each NVM port (NVM_CS_N, NVM_SI, NVM_SK, NVM_SO) and each also has JTAG ports (JTAG_CLK, JTAG_TDI, JTAG_TDO, JTAG_TMS).
and WGI210 MDI port connected each transformer and RJ connectors.
I'm asking how to set each MAC  of each ethernet port.
If setting or fusing flash memory for MAC, what tools (H/W, S/W) are needed?
Thanks in advance.
B_Y
Hi @netkerlQuevedoyat,
May I suggest you to consider following tool:
- Intel® Ethernet Flash Firmware Utility, guides:
https://www.intel.com/content/www/us/en/support/articles/000005790/software/manageability-products.html
Kindly reach out to Intel Premier Support (IPS) to get support on design inquiries.
Steps on How to Register and have Access to Intel® Premier Support:
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Alternatively, you may proceed to post a question on Intel Embedded Communities:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future related to Ethernet Products as this thread will no longer be monitored.
Thank you.
BY_Intel
Intel Customer Support
