Ethernet Products
5777 Discussions
PROSET 28.0 cmdlet error on W10 LTSC 1809
mfg
On W10 LTSC 1809 I've installed latest driver and Proset package (28.0) to add a VLAN tag to ethernet adapter
I've 2 network card (SSU detail attached):
- "Intel(R) I210 Gigabit Network Connection"
- "Intel(R) Ethernet Connection I219-LM"
I tried Get-IntelNetAdapter and Add-IntelNetVLAN powershell cmdlets.
Both fail with "Provider load failure" error.
I tried downgrading to the oldest available package (22.10) but the problem is the same.
In another pc identical to this one cmdlets seems to work (i tried Get-IntelNetAdapter only)
It has ProSet 20.4.308.0 version installed, but this is version is not longer available
Could you please help.
B_Y
Hi @mfg ,
In order to better assist you, we recommend for you to provide below information:
1. May I know if the issue existed before the installation / upgrade to Intel Proset package (28.0)? Can I know the steps and source/link you got for the Intel Proset package (28.0)?
2. May I know if you are using Intel server board or other OEM motherboard/system configuration.
3. Have you try to clean uninstall the Intel® PROSet Software and reinstall with older version driver?
BY_Intel
Intel® Customer Support
mfg
Proset was not installed before. I've installed it to configure VLAN tagging
I've downloaded it from intel website by searching for "Intel(R) I210 Gigabit Network Connection driver"
Landing page: https://www.intel.it/content/www/it/it/download/18293/intel-network-adapter-driver-for-windows-10.html
Download link: https://downloadmirror.intel.com/772070/Wired_driver_28.0_x64.zip
It' an industrial oem system CINCOZE DS-1100
Yes, installation of 22.10 version was made after disinstalling 28.0 from "Program and features" uninstall shortcut
mfg
Hi B_Y,
thanks for reply
landing page: https://www.intel.it/content/www/it/it/download/18293/intel-network-adapter-driver-for-windows-10.html
download link: https://downloadmirror.intel.com/772070/Wired_driver_28.0_x64.zip
it is an OEM embedded system CINCOZE DS-1100
From the manufacturer's website I fetched the installer for ProSet 20.4.308.0
cmdlets Get-IntelNetAdapter works, but this version does not support Add-IntelNetVLAN on Windows 10
Yes, all installations were made after disinstalling previous installed package from "Program and features" uninstall shortcut
B_Y
Hi @mfg ,
Thank you for your patience.
Proset is not supported for Ethernet model: I219-LM
On the other hand, the cmdlets need to be imported before they will work on I210. The e-doc: “Adapters and Devices User Guide” below will describe how the Powershell cmdlets may incorporate according to your needs.
It is at Section 3.5.1, page: 21.
https://cdrdv2-public.intel.com/705831/Adapter_User_Guide.pdf
May I ask if other cmdlet/s is working, other than these 2 cmdlets: "Get-IntelNetAdapter and Add-IntelNetVLAN" that you have tested?
Looking forward to hearing from you. Thank you.
BY_Intel
B_Y
Hi @mfg ,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
Thank you.
BY_Intel
mfg
in previous tests the import-module command was always used according to manual.
I haven't tried other cmdlets than "Get-IntelNetAdapter and Add-IntelNetVLAN"
Now I can't devote any more time to this problem.
I solved my use case by adding a managed switch near the user.
It is an increase in costs and in the complexity of the installation, but that's the way it is
Thanks anyway for your attempt to help me
Bye
B_Y
Hi @mfg ,
Thank you for the feedback and glad it is resolved. Please be informed that we will now close this request since you have found the solution. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you.
BY_Intel
