Ethernet Products
5736 Discussions
WGI210AT (I210) flash-less (NVM-less) OS Memory Resources Issue
Insu-ATI
Hi everyone,
We used WGI210AT to design a NIC and wanted to remove an external flash.
I programmed 'I210_Invm_Copper_NoAPM_v0.6' to the I210 using the Lanconf_1.38.10.0.
I checked the NIC after a power cycle and noted a warning mark on the network adaptor.
I checked the NIC using the Lanconf_1.38.10.0 and it showed the following message.
When I push the Enter key, it showed the following.
And I checked the OS memory resources which was the following.
I tested a WGI211 with the same PCBA with 'I211_Invm_NoAPM_v0.6.txt'. And this board worked well, and I saw the Memory resource was different.
Thanks for reading and please provide any comments or ideas.
Kind regards,
Insu
Azeem_Intel
Hi Insu-ATI,
Greetings for the day!
Hope you are doing well. Your query would be best addressed by our Embedded support team. I kindly request you to submit your query using the link provided below: [https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products]
Azeem_Intel
