Ethernet Products
5864 Discussions
WGI210AT Xtal2 GND connection
EnrGtt
On WGI210AT, when using an external oscillator Xtal 2 must be grounded. (11.6.5.2 page 800 ).
Xtal2 is an output, chapter 11.6.5.2 External Clock Oscillator Specifications, could it be in error?
Can I see a schematic diagram of the internal clock circuit of the WGI210 Ethernet Controller?
BR
Enrico Gatti
Faez_Intel
Hi Enrico,
Good day. For these inquiries, you may inquire this on our Intel Developer Zone website instead for any engineering related questions. Refer the link below:
https://www.intel.com/content/www/us/en/developer/overview.html#gs.y5e8xi
Kindly let us know if you have any other inquiries or clarifications.
Faez.
Intel Customer Support
Faez_Intel
Hi Enrico,
Good day and thank you for contacting Intel Community Support.
You may kindly refer to our Resource and Documentation Center to refer the schematics of the I210-AT NIC. Refer below link:
https://www.intel.com/content/www/us/en/search.html?ws=recent#q=i210%20schematic&sort=relevancy&f:@tabfilter=[Developers]
Kindly let us know if you have any other inquiries.
Faez.
Faez_Intel
Hi Enrico,
Good day. This is just a follow up on this thread.
Please kindly let us know if you have any other inquiries and we will assist you accordingly. If you have additional questions or clarifications, feel free to let us know.
Faez.
EnrGtt
Hi Faez, thanks for your availability,
even if I provided a 0 Ohm resistor on pin 45 Xtal2, connected to ground as described on the Intel® Ethernet Controller I210 datasheet, to avoid surprises, I'm pleased to go into depth before starting the tests on the new project.
On page 800, (Intel® Ethernet Controller I210 Datasheet), fig.11-9: XTAL2(Out) connect to GND !
The comment to paragraph 11.6.5.2 says : When using an external oscillator the following connection must be used.
This connection,(XTAL2 TO GND), is not foreseen in the document : Intel® Ethernet I210-AS/IS Reference Design: Schematic, sheet 5, when used Y4.
Best Regards
Enrico Gatti
Faez_Intel
Hi Enrico,
Faez.
