Hi everyone,
I'm working with Intel(R) Ethernet CNA x710 DA4 FH that has 4 ports and I want to capture high rate data (more than 3 Gb per second per port). First, I tested to capture 3.3 Gb rate data from one port. It was good without any loss. Fig.1 shows the CPU cores load. But when I want to capture data from two or more ports simultaneously, I have a lot of losses, also CPU load is just on one core. Figs 2-4 show CPU load for 2, 3, and 4 port data capturing respectively.
anyone can help me to distribute load on different cores? I think it can remove losses.
Or how can I capture data without loss?
I work by Windows server 2016 OS, WinPcap 4.1.3 to capture data, Visual studio 2013 and C program.
Fig.5 shows my Ethernet card feature.
Thank you in advance.
Hello Miladdona,
You're welcome.
Please allow us to forward your reply to our engineers. We will get back to you as soon as we heard from them but no later than 2-4 business days.
Crisselle C.
Intel Customer Support
Hello Miladdona,
Good day!
We'd like to inform you that we are still actively working on this issue with our higher level Engineers. Rest assured that we will keep you posted and get back to you within 2-4 business days.
Hoping for your kind patience.
Crisselle C.
Hello Miladdona,
Thank you for the patience on this matter.
Kindly refer to below information for the update from our engineering team.
Here are some tuning notes that should be helpful in getting multi port performance to improve in window.
Please refer to the detailed documentation in the Ethernet User Guide (https://downloadcenter.intel.com/download/28410/Adapter-User-Guide-for-Intel-Ethernet-Adapters) in a section called “Optimizing Performance.”
Here are the major tunable parameters:
Adjust RSS settings (controlled through RSS configuration, see https://docs.microsoft.com/en-us/powershell/module/netadapter/set-netadapterrss?view=win10-ps)
For multiple adapter ports, pin queues to non-overlapping CPU cores. Avoid core 0 since it performs system tasks. Increase number of RSS queues if needed. (in this case, this may be difficult as you only have 8 cores available on the client processor)
Example:
Get-NetAdapter -InterfaceDescription *X710*
Set-NetAdapterRss -name <adapter name> -NumberOfReceiveQueues $numrss -BaseProcessorNumber $numoffset -BaseProcessorGroup $localnode
Adjust RSS numa profile to "Closest" to allow more efficient processing of queues on the local numa node.
Example:
Set-NetAdapterRss -name <adapter name> -Profile Closest
Running more application threads will allow more queues and CPU cores to be used.
Most relevant section from the user guide:
Visit page 40 "RSS Queues" of Ethernet User Guide
Awaiting to hear from you.
Should there be no response, I’ll make sure to reach out after 3 business days.
Crisselle C.
Hello Miladdona,
Good day!
This is just a follow up to check if you have read our previous message. In case you need clarifications on this one, please let us know and we will be glad to communicate this to our engineers.
We will follow up after 3 business days if we don't hear from you.
Crisselle C.
Hello Miladdona,
Appreciate your effort in trying out the recommended steps to improve multi port performance on Windows.
We are sorry to hear that it didn't help with the issue. Please allow us to re-escalate this issue with our engineers and ask for their insight. We will get back to you as soon as possible but no later than 2-4 business days.
Crisselle C.
Hello Miladdona,
Please see below details for the recommendations from our engineering team.
The screenshot provided shows that you are using 32 RSS queues. The platform used is a client board with an 8 core i7. With this, they would recommend to reduce the RSS queue count to 4 for each of the 10G ports. Set the first adapter RSS base processor number to 0 and the second to 4. This will ensure each queue gets pinned to unused cores.
Please dump the RSS config for each port using "Get-NetAdapterRss"
Additionally, they suggested that you attempt to sanity check the test environment using a traditional network benchmark tool such as netperf or iperf.
Also, we hope you don't mind providing the additional information below as per their request.
1.) Is the adapter installed in the correct speed PCIe slot?
2.) What is the link partner in this case, is it also a client platform?
3.) What is the memory configuration of the system, if not all memory channels are populated it could reduce the available bandwidth.
Looking forward to hear from you.
Crisselle C.
