Ethernet Products
5821 Discussions
Windows Miniport source codes
DavescZw
Good day. I would like to know if Intel publishes Miniport driver source codes  for windows. The only source codes for Network adapters I see are for Linux OS.
Poojitha
Hi DavescZw,
Greetings for the day!
In order to the obtain the Windows Miniport source codes you will need to submit an Intel® Premier Support (IPS) case.
In case you don't have access to the IPS platform please check below links:
Thank you for your support and understanding!
Poojitha
Dineshbabu
Hi DavescZw,
Greetings!
Thank you for posting in the Intel Community. Please confirm if there are any particular device that you are looking for miniport driver.
Dinesh
DavescZw
Im looking for the Windows NDIS Miniport source codes for the adapters listed below.
Intel Ethernet controller X710-BM2 (10 Gbps)
or 500 Gb series (10 Gbps)
Intel 82599 10 Gigabit Ethernet Controller
Intel Ethernet X550
Intel Ethernet Connection X557
Intel Ethernet Converged Network Adapter X550
or the 800 series
Intel ethernet controller E810 (100 Gbps)
These adapters can process 10 gbps except for E810 which is 100 Gb.
I would like to know if you have *Windows) NDIS Miniport source code for these adapters
Dineshbabu
Hi DavescZw,
Thank you for your response. Please allow us some time to review the details and we will get back with an update shortly.
Dinesh
Poojitha
Hi DavescZw,
Poojitha
