Ethernet Products
5744 Discussions
Wireshark/Tshark on Host SR-IOV Interface
EWolf5
Greetings
I am working on testing a DPDK based VM and need to see if packets are really leaving the host interface. I am using an HP DL-380 server with Intel based 10G nics. I have enabled SR-IOV and am using 1 VF on each of 2 PFs. I want to sniff packets on the host but when I start tshark on the PF device I do not see any packets. but I know they are are passing to the VM (some of them anyway). How can you setup the PF to be able to see
traffic to the VF or when the VF is enabled it completely bi-passes this capability?
Host Info:
root@srvrhp811:~# uname -a
Linux srvrhp811 3.19.0-25-generic # 26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
root@srvrhp811:~# ip link show dev p5p2
11: p5p2: mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 8c:dc:d4:aa:6b:59 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 16:cc:19:fc:33:91, spoof checking off, link-state auto
vf 1 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 2 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 3 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 4 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 5 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 6 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
vf 7 MAC 00:00:00:00:00:00, spoof checking on, link-state auto
root@srvrhp811:~# ip link show dev p2p2
6: p2p2: mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 8c:dc:d4:aa:6c:55 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 02:42:b8:01:a5:0f, spoof checking off, link-state auto
root@srvrhp811:~# ethtool -i p2p2
driver: ixgbe
version: 4.1.5
firmware-version: 0x800007c7, 1.475.0
bus-info: 0000:07:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
root@srvrhp811:~# ethtool -i p5p2
driver: ixgbe
version: 4.1.5
bus-info: 0000:24:00.1
supports-test: yes
Salem_W_Intel1
Hi!
Do your HP* DL-380 server feature onboard "Intel based 10G NICs" or are these external NIC cards? If these are external Intel(R) Network Cards, would you, please, provide the exact model?
EWolf5
These are not embedded NICs. They are the HP branded Intel NIC but the chipset is the
HP ETHERNET 10GB 2P 560SFP+ ADPTR - Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection
Salem_W_Intel1
If this is about an http://ark.intel.com/products/41282/Intel-82599ES-10-Gigabit-Ethernet-Controller?q=82599ES Intel® 82599ES 10 Gigabit Ethernet Controller, indeed, then, please, know this thread will be forwarded to the corresponding, NIC Dpt.
st4
New Contributor III
Hi ericjwolf,
With regards to your inquir, please access to http://premier.intel.com/premier http://premier.intel.com/premier for further support.
rgds,
wb
