Ethernet Products
5736 Discussions
XL710-QDA1 lost after NVM upgrade
J_Tay
We've recently upgraded the OS on a host with a XL710-QDA1 card, and the newer i40e driver started complaining about the NIC firmware being too old. We downloaded the latest NVM update tool from intel.com (9.30) and after flashing the card, the driver started complaining about:
[ 421.125559] i40e 0000:01:00.0: PF reset failed: -15
[ 421.125567] i40e 0000:01:00.0: Entering recovery mode due to repeated FW resets. This may take several minutes. Refer to the Intel(R) Ethernet Adapters and Devices User Guide.
[ 421.125727] i40e: probe of 0000:01:00.0 failed with error -15
 and the interfaces have disappeared. Running nvmupdate64e gives "Access error"
02) Intel(R) Ethernet Converged n/a(n/a) 1583 00:001 Access error Network Adapter XL710-Q1
The card has a PBA of H57400-003, MAC 6805CA357258 and has a yottamark sticker at the back which passes validation
How can we restore the card to functioning state?
Yogaeasvaran
Greeting J Tay,
Thank you contacting Intel Customer Support.
We understand you have faced the issue with Ethernet Adapter 700m Series.
Could you please provide us SSU logs follow the link below:
Yogaeasvaran
Srri
Hello J Tay,
Regarding your case we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Srri
Yogaeasvaran
Hello J Tay,
Regarding your case, we are following up 2nd time to find out if you were able to complete the actions we previously recommended.
Yogaeasvaran
Yogaeasvaran
Hello J Tay,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Yogaeasvaran
