Ethernet Products
5862 Discussions
XL710 QDA2 link not detected.
PKuru
I have setup my server (PowerEdge R620) with CentOS 7 and attached XL710-QDA2 40GbE NIC card on PCIe 3 slot. The driver i40e is updated to the latest version 2.4.10 and using compatible QSFP 4 x 10 GbE module / cable (https://www.intel.com/content/www/us/en/ethernet-products/optics-cables/ethernet-qsfp-cables-brief.html X4DACBL5) as shown in the link: https://www.intel.com/content/www/us/en/support/articles/000006051/network-and-i-o/ethernet-products.html QSFP+ Modules/Cables Compatible with Intel® Ethernet Server Adapter...
However, though ifconfig shows the interface is up, it does not detect the link or the cable attached. The LED near the port does not light up.
Do I need to install any other drivers for the SFP module? Am I missing something here?
Prakash
Hello Prakashkurup7,
Thank you for posting in Intel Wired Ethernet Communities. Do you have a spare cable or adapter you can swap out to test each part? Please post the following outputs from the terminal in CentOS:
ehtool -i  ethtool
modinfo i40e
Please let me know if you have any questions.
Daniel D
Intel Customer Support
Agent under contract to Intel
We would like to help you with this issue. Please inform us if you have not resolved the issue. If you have any questions please let us know..
Daniel D
apapr
I am also facing same issue, please guide me how to overcome this issue?
apapr
I am also facing same issue, below if output of modinfo i40e
filename: /lib/modules/4.4.0-31-generic/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version: 2.7.29
license: GPL
description: Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author: Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion: 2212C8D31172FBDBC9A1647
alias: pci:v00008086d0000158Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000158Asv*sd*bc*sc*i*
alias: pci:v00008086d000037D3sv*sd*bc*sc*i*
alias: pci:v00008086d000037D2sv*sd*bc*sc*i*
alias: pci:v00008086d000037D1sv*sd*bc*sc*i*
alias: pci:v00008086d000037D0sv*sd*bc*sc*i*
alias: pci:v00008086d000037CFsv*sd*bc*sc*i*
alias: pci:v00008086d000037CEsv*sd*bc*sc*i*
alias: pci:v00008086d00001588sv*sd*bc*sc*i*
alias: pci:v00008086d00001587sv*sd*bc*sc*i*
alias: pci:v00008086d000015FFsv*sd*bc*sc*i*
alias: pci:v00008086d00001589sv*sd*bc*sc*i*
alias: pci:v00008086d00001586sv*sd*bc*sc*i*
alias: pci:v00008086d00001585sv*sd*bc*sc*i*
alias: pci:v00008086d00001584sv*sd*bc*sc*i*
alias: pci:v00008086d00001583sv*sd*bc*sc*i*
alias: pci:v00008086d00001581sv*sd*bc*sc*i*
alias: pci:v00008086d00001580sv*sd*bc*sc*i*
alias: pci:v00008086d00001574sv*sd*bc*sc*i*
alias: pci:v00008086d00001572sv*sd*bc*sc*i*
depends: ptp,vxlan
vermagic: 4.4.0-31-generic SMP mod_unload modversions
parm: debug:Debug level (0=none,...,16=all) (int)
output for ethtool enp8s0f1
 Settings for enp8s0f1:
Supported ports: [ ]
Supported link modes: 40000baseCR4/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: 40000baseCR4/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: external
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000000f (15)
drv probe link timer
Link detected: no
Amit
apapr
Can anyone please guide how to overcome this issue?
