Ethernet Products
4545 Discussions
XL710 QDA2 - link not
yzhou37
I have two XL710 QDA2 nics each is installed on a server (ubt 18.04, kernel 4.15.0-43-generic), then use QSFP+ DAC 3.0m cable to connect them back to back. The i40e driver has been updated to latest 2.7.26. But ethtool still shows link not detected, and all LEDs on both nics are black.
$ ethtool ens5f0
Settings for ens5f0:
Supported ports: [ ]
Supported link modes:  40000baseCR4/Full
            40000baseSR4/Full
            40000baseLR4/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 40000baseCR4/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x0000000f (15)
    drv probe link timer
Link detected: no
$ modinfo i40e
filename:    /lib/modules/4.15.0-43-generic/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version:    2.7.26
license:    GPL
description:  Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author:     Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion:   7B91C68FBC788EFDF1D32BF
alias:     pci:v00008086d0000158Bsv*sd*bc*sc*i*
alias:     pci:v00008086d0000158Asv*sd*bc*sc*i*
alias:     pci:v00008086d000037D3sv*sd*bc*sc*i*
alias:     pci:v00008086d000037D2sv*sd*bc*sc*i*
alias:     pci:v00008086d000037D1sv*sd*bc*sc*i*
alias:     pci:v00008086d000037D0sv*sd*bc*sc*i*
alias:     pci:v00008086d000037CFsv*sd*bc*sc*i*
alias:     pci:v00008086d000037CEsv*sd*bc*sc*i*
alias:     pci:v00008086d00001588sv*sd*bc*sc*i*
alias:     pci:v00008086d00001587sv*sd*bc*sc*i*
alias:     pci:v00008086d000015FFsv*sd*bc*sc*i*
alias:     pci:v00008086d00001589sv*sd*bc*sc*i*
alias:     pci:v00008086d00001586sv*sd*bc*sc*i*
alias:     pci:v00008086d00001585sv*sd*bc*sc*i*
alias:     pci:v00008086d00001584sv*sd*bc*sc*i*
alias:     pci:v00008086d00001583sv*sd*bc*sc*i*
alias:     pci:v00008086d00001581sv*sd*bc*sc*i*
alias:     pci:v00008086d00001580sv*sd*bc*sc*i*
alias:     pci:v00008086d00001574sv*sd*bc*sc*i*
alias:     pci:v00008086d00001572sv*sd*bc*sc*i*
depends:    ptp
retpoline:   Y
vermagic:    4.15.0-43-generic SMP mod_unload
parm:      debug:Debug level (0=none,...,16=all) (int)
The DAC cable we are using: https://www.dustinhome.se/product/5010976356/ethernet-qsfp-twinaxial
Daniel_D_Intel1
Hello Yzhou37, Thank you for posting in Intel Ethernet Communities. Have the adapters worked previously with other operating systems or kernels? Please confirm the PCIe ports on the server are supplying 8x of power. Do other adapters or devices work on the PCIe ports? Is the adapter detected using (lspci -nn | grep -i 'Ethernet Controller')? Please provide the output of the lspci command and (ethtool -i ens5f0) to display the firmware. Please supply the markings from the adapter if you have physical access. Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support
Daniel_D_Intel1
Hello Yzhou37, Please let us know if you still need assistance with this issue. Please provide the outputs and markings requested. Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Daniel_D_Intel1
Hello Yzhou37, Please let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Shubhakar
Hi ,
I am Facing the same issues with Intel XL710 After Updating the Firmware to 2.7.27
yzhou37
Hi Daniel,
Sorry for late reply, some problem when login my account. It works now with latest driver  2.7.26 and latest firmware version.
BR
Yu
Daniel_D_Intel1
Hello Yzhou37, Thank you for the reply. Updating the firmware solved the issue? Please let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
