E810XXVDA4TG1
Version: M40206-005
ice (Linux): 1.17.4
NVM version: 4.80
From lspci:
Capabilities: [e0] Vital Product Data
Product Name: Intel(R) Ethernet Network Adapter E810-XXVDA4T\x00\x00
Read-only fields:
[V1] Vendor specific: Intel(R) Ethernet Network Adapter E810-XXVDA4T
[PN] Part number: M56952-005
[SN] Serial number: 507C6F843534
[V2] Vendor specific: 1625
[RV] Reserved: checksum good, 1 byte(s) reserved
I am using external GPSDO with 1 PPS and 10MHz outputs.
I would like to connect them to the SMA inputs.
646265_Intel® Ethernet Network Adapter E810-XXVDA4T User Guide_Rev1_7 describes using 1 PPS but is vague on using 1 PPS and 10MHz together.
Is there a recommended configuration?
I currently have the following:
-> 1 PPS from GPSDO going to SMA1
export ETH=enp1s0f0np0
# SMA1 as input:
echo 1 > /sys/class/net/$ETH/device/SMA1
cat /sys/class/net/$ETH/device/pin_cfg
in
| pin| enabled| state| freq| phase_delay| eSync/Ref-sync| DPLL0 prio| DPLL1 prio|
| 0| 1| invalid| 1| 0| 0| 255| 5|
| 1| 1| invalid| 1| 0| 2| 255| 4|
| 2| 1| invalid| 1953125| 0| 0| 8| 8|
| 3| 1| invalid| 1953125| 0| 0| 9| 9|
| 4| 1| valid| 1| 7000| 0| 3| 3|
| 5| 1| invalid| 1| 7000| 2| 2| 2|
| 6| 1| invalid| 1| 0| 0| 0| 0|
out
| pin| enabled| dpll| freq| esync|
| 0| 1| 1| 1| 0|
| 1| 1| 1| 1| 0|
| 2| 1| 0| 156250000| 0|
| 3| 1| 0| 156250000| 0|
| 4| 1| 1| 1| 0|
| 5| 1| 1| 1| 0|
Note: I ran the suggested "setup script for version 4.80 and later"
Can I just add the following:
# SMA 2 as input:
echo 1 > /sys/class/net/$ETH/device/SMA2
# Set SMA2 input frequency to 10MHz
echo "in pin 5 freq 10000000" > /sys/class/net/$ETH/device/pin_cfg
Hi Quantum-Aisle-LLC,
Thank you for posting in Intel Community Forum.
Based on the Intel documentation for the E810-XXVDA4T adapter (NVM 4.80, ICE driver 1.17.4), this adapter supports simultaneous use of SMA1 and SMA2 for external timing inputs, including 1PPS and 10MHz signals. You may refer link below for your reference:
Intel® Ethernet Network Adapter E810-XXVDA4T User Guide:
You may also refer to product datasheet:
https://www.intel.com/content/www/us/en/support/articles/000093196/ethernet-products.html
Also, we recommend you to refer to Intel Github:https://github.com/intel/ethernet-linux-ice
If you still require further information regarding this, you can open Intel Premier Support (IPS) case for further support (https://premiersupport.intel.com/).
Hope this clarifies.
Sazzy_Intel
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
