Ethernet Products
5740 Discussions
ice 1.7.16 VF device is missing while deploying workloads
Nag08
Hello Team,
we are using the following versions in our device:
  1. ice: v1.7.16
  2. iavf: v4.3.19
  3. firmware: ice/ddp/ice-1.3.27.0.pkg
  4. uname -a
    Linux appliance-1.chassis.local 4.18.0-553.50.1.1.el8_10.x86_64 x86_64 x86_64 x86_64 GNU/Linux
Issue Description:
When deploying our workloads, we are seeing an issue with respect to VF device. Even though PCI sys bus directories are fine, vf is missing under ip link show command.
To reproduce this, we developed a script which performs setting random mac address to VFs under PF. We got the issue in 14th iteration.
We tried different workarounds (unbind, bind) , but we are not able to bring VF device back.
System status as below, when the issue is hit:
[root@appliance-1:Active] ~ # ip link show sfp_5
6: sfp_5: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
    link/ether 14:a9:d0:04:1c:03 brd ff:ff:ff:ff:ff:ff
    vf 0     link/ether 02:cd:86:f1:f9:75 brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state auto, trust on
    vf 2     link/ether 00:00:00:00:01:04 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state enable, trust off
    vf 3     link/ether 00:00:00:00:01:04 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state enable, trust off
    altname enp236s0f0
Truncated VF list: sfp_5
Logs are as below:
dmesg Logs of that particular VF device:
[Mon Jul  7 12:37:37 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:38 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:38 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -5 (IAVF_ERR_PARAM) to our request 3
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 51
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 44
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 7
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: Failed to add MAC filter, error IAVF_NOT_SUPPORTED
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 52
[Mon Jul  7 12:37:39 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 6
[Mon Jul  7 12:37:40 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:40 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:41 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:41 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:42 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:42 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:43 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:43 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:44 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:44 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:45 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:45 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:46 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:46 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:47 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:47 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:48 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:48 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:49 2025] iavf 0000:ec:01.1 eth2: NIC Link is Up Speed is 10 Gbps Full Duplex
[Mon Jul  7 12:37:49 2025] iavf 0000:ec:01.1: Reset indication received from the PF
[Mon Jul  7 12:37:49 2025] iavf 0000:ec:01.1: PF returned error -5 (IAVF_ERR_PARAM) to our request 3
[Mon Jul  7 12:37:49 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 51
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 44
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 7
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: Failed to add MAC filter, error IAVF_NOT_SUPPORTED
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 52
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 6
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 8
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 23
[Mon Jul  7 12:37:50 2025] iavf 0000:ec:01.1: PF returned error -64 (IAVF_NOT_SUPPORTED) to our request 24
Script logs :
[root@appliance-1:Active] ~ # ./set_mac_2.sh 500
Iteration 1: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:14:28:48:fb:27 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:1d:f7:a1:64:9c spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:d6:a7:97:f1:cb spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:7d:e4:9d:42:43 spoofchk=on state=auto trust=on
Iteration 1: Unsetting all VFs on sfp_5
  - Unsetting VF 0: MAC=00:00:00:00:01:04 spoofchk=off state=enable trust=off
  - Unsetting VF 1: MAC=00:00:00:00:01:04 spoofchk=off state=enable trust=off
  - Unsetting VF 2: MAC=00:00:00:00:01:04 spoofchk=off state=enable trust=off
  - Unsetting VF 3: MAC=00:00:00:00:01:04 spoofchk=off state=enable trust=off
Iteration 2: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:ee:33:28:76:eb spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:08:dd:39:6b:0e spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:9f:49:da:6e:95 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:39:cf:8d:cc:92 spoofchk=on state=auto trust=on
Iteration 2: Unsetting all VFs on sfp_5
Iteration 3: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:a2:29:33:ba:fd spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:3e:13:0c:67:b3 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:c7:5d:a3:54:78 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:81:4a:c9:92:7c spoofchk=on state=auto trust=on
Iteration 3: Unsetting all VFs on sfp_5
Iteration 4: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:9f:9c:01:d1:53 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:58:7e:20:29:df spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:78:61:ff:f2:f1 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:9b:eb:0d:e5:1b spoofchk=on state=auto trust=on
Iteration 4: Unsetting all VFs on sfp_5
Iteration 5: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:e3:f8:55:84:82 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:7b:d4:2b:61:e9 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:c3:a0:89:e2:aa spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:88:e5:c8:5b:0a spoofchk=on state=auto trust=on
Iteration 5: Unsetting all VFs on sfp_5
Iteration 6: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:4a:68:60:1d:36 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:29:6e:9d:7b:d7 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:86:7e:aa:40:f5 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:62:2a:24:f8:4a spoofchk=on state=auto trust=on
Iteration 6: Unsetting all VFs on sfp_5
Iteration 7: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:21:86:9f:b5:bc spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:99:02:04:b5:e5 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:62:db:98:45:5c spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:ef:f3:dd:ec:b1 spoofchk=on state=auto trust=on
Iteration 7: Unsetting all VFs on sfp_5
Iteration 8: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:e2:b4:0b:f6:c6 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:3f:a2:0e:b4:9a spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:05:58:5f:be:1e spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:56:18:4b:be:6e spoofchk=on state=auto trust=on
Iteration 8: Unsetting all VFs on sfp_5
Iteration 9: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:0d:aa:ff:39:6f spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:de:66:95:ab:99 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:4e:79:eb:a2:66 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:a3:4d:ff:4a:10 spoofchk=on state=auto trust=on
Iteration 9: Unsetting all VFs on sfp_5
Iteration 10: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:37:a3:af:b0:21 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:24:c7:66:19:9b spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:e9:5c:fe:c7:c1 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:ab:77:86:16:e5 spoofchk=on state=auto trust=on
Iteration 10: Unsetting all VFs on sfp_5
Iteration 11: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:81:12:4f:70:49 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:53:2f:db:cc:9d spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:84:f1:ae:47:b6 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:43:71:df:d3:ca spoofchk=on state=auto trust=on
Iteration 11: Unsetting all VFs on sfp_5
Iteration 12: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:42:dd:c8:4d:66 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:3a:ac:b3:5f:0b spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:61:e5:f6:46:e1 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:73:53:84:12:39 spoofchk=on state=auto trust=on
Iteration 12: Unsetting all VFs on sfp_5
Iteration 13: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:92:70:c2:22:2b spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:10:73:ac:f0:35 spoofchk=on state=auto trust=on
  - Setting VF 2: MAC=02:6a:d5:e0:6c:39 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:be:8f:9c:44:c5 spoofchk=on state=auto trust=on
Iteration 13: Unsetting all VFs on sfp_5
Iteration 14: Setting all VFs on sfp_5
  - Setting VF 0: MAC=02:4f:98:bf:d9:16 spoofchk=on state=auto trust=on
  - Setting VF 1: MAC=02:c4:ba:3b:07:d1 spoofchk=on state=auto trust=on
RTNETLINK answers: Invalid argument
  - Setting VF 2: MAC=02:43:13:fc:00:72 spoofchk=on state=auto trust=on
  - Setting VF 3: MAC=02:ce:8c:44:e0:87 spoofchk=on state=auto trust=on
Iteration 14: Unsetting all VFs on sfp_5
Script Content:
root@appliance-1:Active] ~ # cat set_mac_2.sh
#!/bin/bash
# Script to set random MAC and other VF settings for ALL VFs on PF sfp_5
PF="sfp_5"
usage() {
    echo "Usage:"
    echo "  $0 <ITERATION_COUNT>"
    echo "Example:"
    echo "  $0 5"
    exit 1
if [[ $# -ne 1 ]]; then
    usage
fi
ITERATIONS=$1
DEFAULT_MAC="00:00:00:00:01:04"
generate_random_mac() {
    printf '02:%02x:%02x:%02x:%02x:%02x\n' \
        $((RANDOM%256)) $((RANDOM%256)) $((RANDOM%256)) $((RANDOM%256)) $((RANDOM%256))
for (( i=1; i<=ITERATIONS; i++ ))
do
    echo "Iteration $i: Setting all VFs on $PF"
    for VF in 0 1 2 3
    do
        RANDOM_MAC=$(generate_random_mac)
        echo "  - Setting VF $VF: MAC=$RANDOM_MAC spoofchk=on state=auto trust=on"
        ip link set $PF vf $VF mac $RANDOM_MAC spoofchk on state auto trust on
    done
    echo "Iteration $i: Unsetting all VFs on $PF"
    for VF in 0 1 2 3
    do
        echo "  - Unsetting VF $VF: MAC=$DEFAULT_MAC spoofchk=off state=enable trust=off"
        ip link set $PF vf $VF mac $DEFAULT_MAC spoofchk off state enable trust off
    done
    echo ""
done
We know that, drivers being used are old. If there is any patch or fix provided in the later releases of the drivers we would try to patch in this version of Driver.
This issue is been there for a while and hitting in the customers location more often. Looking forward for a quick resolution on this.
Thank you!
Nagaraj Gidde
Fikri_Intel
Hi Nag08,
Good day to you.
Just wanted to follow up with you, kindly let us know if you have any further concerns.
Fikri O.
Fikri_Intel
Hi Nag08,
Good day to you.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Fikri O.
