Ethernet Products
5714 Discussions
igb + I350-T2 Offline Test Fails with Linux 2.6.33
Sde_W
I am evaluating the Ethernet Server Adapter I350-T2 to replace our previous end of life card. I have not had any issues with the card during my operational tests but when I execute the cards offline tests the network interface goes offline and requires the network service to be restarted. My concern that there is some real instability between my hardware/software and the I350 that could manifest in failures over prolonged use.
Here are my test results and kernel log data.
$ sudo ethtool --test eth2 offline
Cannot get strings: No such device
2016-03-03 11:04:34.833 localhost kernel: igb 0000:01:00.0: offline testing starting
2016-03-03 11:04:34.833 localhost kernel: igb 0000:01:00.0: eth2: igb: eth2 NIC Link is Down
2016-03-03 11:04:36.508 localhost kernel: igb 0000:01:00.0: eth2: igb: eth2 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
2016-03-03 11:04:36.943 localhost avahi-daemon[948]: Interface eth2.IPv4 no longer relevant for mDNS.
2016-03-03 11:04:36.943 localhost avahi-daemon[948]: Leaving mDNS multicast group on interface eth2.IPv4 with address 192.168.50.2.
2016-03-03 11:04:36.944 localhost kernel: igb 0000:01:00.0: eth2: PCIe link lost, device now detached
2016-03-03 11:04:36.944 localhost kernel: igb 0000:01:00.0: pattern test reg 002C failed: got 0x0000FFFF expected 0x00005A5A
2016-03-03 11:04:38.621 localhost kernel: igb 0000:01:00.0: testing shared interrupt
2016-03-03 11:04:40.315 localhost kernel: igb 0000:01:00.0: Cannot do PHY loopback test when SoL/IDER is active.
2016-03-03 11:04:45.155 localhost avahi-daemon[948]: Withdrawing address record for fe80::a236:9fff:XXXX:XXXX on eth2.
2016-03-03 11:04:45.155 localhost avahi-daemon[948]: Withdrawing address record for 192.168.50.2 on eth2.
2016-03-03 11:04:45.155 localhost ntpd[2499]: Deleting interface # 8 eth2, fe80::a236:9fff:XXXX:XXXX# 123, interface stats: received=0, sent=0, dropped=0, active_time=6201 secs
2016-03-03 11:04:45.155 localhost ntpd[2499]: Deleting interface # 4 eth2, 192.168.50.2# 123, interface stats: received=0, sent=0, dropped=0, active_time=6201 secs
Why is this offline test failing? Should I even worry that this test fails? Does anybody have some tips as to what I should change/fix/do to get the test to pass?
Stephan
Some background details:
OS: Linux Fedora 13
Motherboard: AIMB-780 w/ Intel Core i5-660
$ sudo ethtool -i eth2
driver: igb
version: 5.3.3.5
firmware-version: 1.63, 0x80000cbb
bus-info: 0000:01:00.0
$uname -r
2.6.33.5-112.fc13.i686.PAE
$ sudo lspci -s 01:00 -nnvvvk
01:00.0 Ethernet controller [0200]: Intel Corporation I350 Gigabit Network Connection [8086:1521] (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter I350-T2 [8086:0002]
Physical Slot: 128
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 16
Region 0: Memory at fbd00000 (32-bit, non-prefetchable) [size=1M]
Region 3: Memory at fbcfc000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port # 0, Speed 5GT/s, Width x4, ASPM L0s L1, Latency L0 unlimited, L1 <32us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number a0-36-9f-ff-ff-87-06-7c
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
IOVSta: Migration-
Initial VFs: 8, Total VFs: 8, Number of VFs: 8, Function Dependency Link: 00
VF offset: 384, stride: 4, Device ID: 1520
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 00000000c0000000 (64-bit, prefetchable)
Region 3: Memory at 00000000c0020000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] # 17
Capabilities: [1...
st4
New Contributor III
Hi sdewit,
Thank you for the info. Let me check on this.
rgds,
wb
