Ethernet Products
5777 Discussions
no connection when using static ip on a teamed dual 82575EB, DHCP is fine
I have 2 x Intel S5520HC mobo each with a dual port 82575EB 1000BT onboard NIC. One mobo is using Windows 2008 R2 SP1 and the other Windows 2012.
I team the NICs using "Static Link Aggregation". I can connect to my network as long as the team is set for DHCP.
When I attempt to set the team to a static IP address I can't connect to my network.
Setting a staitc IPs seems to work on PROWinx64.exe version 17 but not on 18.0 and 18.0.1
just before I posted this I saw this a similar issue from 2009.
/message/61068# 61068 http://communities.intel.com/message/61068# 61068
I will re-attempt the team and wait for a long time before setting the static ip and i'll see if it sticks.
Message was edited by: jim okken
i recreated the team and set let it sit for over 10 minutes. both legs of the team were connected and they were using a dhcp address on the network. I could get to network resources and the internet.
I right clicked the "team# 0 nic" and set IPv4 propeties to a staitc IP on the network, they same way I'd do a non-teamed NIC. I lose connection to my network and the internet.
any ideas anyone? thanks
JOkke
i just wanted to bump this issue up again.
does anyone have any ideas about this? it is still happening and is causing a bit of confusion since the machine is a static test bed which had a specific static ip address for sometime, until now.
strange thing: when I have a static ip set for the team, microsoft's network and sharing center says the system is on a domain network but has no internet access. so I run microsoft network diagnostics to see what it suggests I fix, and it actually recommends enabling DHCP.
do teams need to be DHCP? or should there be no problems making a team a static ip address?
again static used to work OK on PROWinx64.exe version 17
thanks!
