Ethernet Products
5743 Discussions
x722-da4 unable to set speed via 'ethtool'
olebenny
Hello community
I am using 2 x x722-da4 in my 'servers'.
1.
If I connect 2 of these servers back to back with fiber-cables, I get links on all channels at 1 Gb.
If I try to:
ethtool -s ens1f2 speed 10000 duplex full autoneg off
responds:
netlink error: link settings update failed
netlink error: Operation not supported
2.
If I unplug one of the SPFs and put it back in, the speed is now changed to 10Gb
3.
[root@localhost ~]# ethtool -a ens1f2
Pause parameters for ens1f2:
Autonegotiate: off
RX: off
TX: off
4.
[root@localhost ~]# ethtool -i ens1f2
driver: i40e
version: 2.17.15
firmware-version: 5.40 0x80002e40 1.2992.0
expansion-rom-version:
bus-info: 0000:b6:00.2
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@localhost ~]#
Mike_Intel
Hello olebenny,
Thank you so much for waiting for our update. Please be reminded that base on PCN, the X722-DA4 successor is E810XXVDA4 or Intel® Ethernet Network Adapter E810-XXVDA4. This card works with multi-rate modules. Base on Ark, it has a Data Rate Per Port of 25/10/1GbE.
Intel Ethernet Network Adapter E810XXVDA4 Product Specifications
We also recommend to use modules based on our compatibility tool.
Intel® Product Compatibility Tool
The X710-DA2 is also a possible replacement. However this does not support iWARP functionality.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
olebenny
Hi Michael
Thank you for updating info about x722-da4 replacement.
You may close this thread now.
Best regards
Ole
Mike_Intel
Hello olebenny,
Thank you so much for the confirmation and we are glad that we are able to help. We will now close this case, if you need assistance again in the future, please post a new question.
You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.
Thank you and stay safe.
Michael L.
