FPGA Intellectual Property
6541 Discussions
Arria10 PCIe: no completion for endpoint MRd
Hello board,
I am using the Arria10 PCIe HIP (avst) as an endpoint.
I have PIO read/write working as well as posted writes. I am trying to get non-posted read working, but I have not had much chance so far.
AFAICT my TLP header looks good, as well as my creds; bus mastering is enabled; but I am not getting neither a completion nor do I see any error reported on the root.
Here is what I am sending (in hex on a 256b bus):
00000000 00000000 00000000 00000000 00000000 00117500 050000FF 00000002
So, in layman terms:
- length = 2 DWORDS
- first/last byte enable : 0xFF (all)
- requested ID : 05:00.00
- host physical address: 0x117500
If anyone has any idea what I am doing wrong, any help would be appreciated.
Thanks !
After fiddling with the transaction size I realized that 1 DWORD read request work. Anything bigger than 1 DWORD is ignored. I read somewhere that Avalon-MM interface has a single-dword completer mode; however, I am using the Avalon-ST interface so I don't think it applies.
So, as it turned out completion were actually sent. It's just that SignalTap would not catch it as it would happen too soon after the previous breakpoint.
