FPGA Intellectual Property
6673 Discussions
Intel Opencl FPGA blocking channel
ADua0
For Opencl FPGA blocking channel , if there are two independent read/write channel operation, are they actually happening in parallel. In the system viewer of report it appears there are no dependencies so I believe they should happen in parallel but how do you verify?
In code sample below what should happen is that b1 and a should happen in parallel with b2 and a2.
Here is example code,
int b1= read_channel_intel(c1);
int b2 = read_channel_intel(c2);
a = b1 *100 ;
a2 = b2 * 200;
write_channel_intel(c1,a);
write_channel_intel(c2,a2);
HRZ
Valued Contributor III
No, independent channel operations happen sequentially and at an order decided by the compiler. This is why mem_fence(CLK_CHANNEL_MEM_FENCE) is provided to avoid potential deadlocks resulting from channel operation re-ordering by the compiler. In your example it is very much possible that the channel operations might result in a deadlock if they are re-ordered by the compiler. You should make sure to use a mem_fence(CLK_CHANNEL_MEM_FENCE) both between the two channel read operations and the two channel write operations to avoid this.
HRZ
ADua0
Okay, so would you recommend adding this memory fence for all the channels I have in my design ?
HRZ
Certainly not; if a certain channel order is required to avoid deadlocks, then you should use a mem_fence to enforce the ordering. If not (i.e. channel operations can be safely re-ordered), then let the compiler decide the order of the operations.
ADua0
By deadlock you meant which channel operations are stalling maximum amount of time?
